Talon TerryH's 1000 X build.....
209,056
Reactions: TerryH
DAJO
182
125
Indiana, Arizona
I've heard of more that had low or no charge than I have fully charged ones. I still cannot figure out why Fox continues with this system instead of jut putting a Schrader on them.
Got my shocks done today at ST. After a little over 700 miles all of them were low on nitrogen charge, fronts only had about 85psi, instead of 200psi according to ST. ST installs schrader valves when they do the work.
Reactions: TerryH
TerryH
TerryH
664
2,241
Springdale, Ar
Took advantage of a day off today to tend to a side project. I had purchased the Erickson Manufacturing UTV trailer tie down system on the open trailer. The system consists of 8 wheel chocks that have E track attached to them and 4 e track straps. Really nice that the double over and sew the end of the straps so they can't slide out of the ratchets. Note that the manufacturer says that 30" tires are the max but there was plenty of strap to go around my 32" Roxxzilla's which actually measure 31".
I loaded the Talon and set the chocks in place. Marked the holes in the chocks and unloaded the Talon. All 4 of the rear chocks had 2 bolts each that matched up with cross members. None of the front bolts hit anything but the wood deck. I used grade 8 bolts with 2" fender washers on the bottom on all the bolts that did not go thru a cross member. All the bolts got nylock nuts.
This is a way better system than the standard crank straps that I've been using.
Link to the kits on Amazon.....
https://www.amazon.com/gp/product/B015CJICIK/?tag=sxsweb24-20
49279772696 94ce18b42f b
49279772636 392282f84a b
49279772466 3461178e24 b
49279975657 7810386087 b
49279772206 b401993c63 b
49279975392 68776cd347 b
PhilCod
PhilCod
355
731
Indiana
Looks good. Thanks for the link. I need to set up my trailer this way. Got the Bandit tender springs on the other day. Not a bad job thanks to your video. I'm waiting on my Rockblox fender flares, A-arm and trailing arm guards to come in this week. Once those are in and put on, I'll take it for a good ride on the farm land around me. Also, we may look at going on a trip to northern Arkansas to ride. If we do I'll hit you up for good places to go, and places to avoid.
TerryH
TerryH
664
2,241
Springdale, Ar
Let me know when you guys are coming. There are rides going on here all the time. Some amazing places to ride here!
TerryH
TerryH
664
2,241
Springdale, Ar
Gotta give a shout out to @Hondasxs for the new adapter for the oversize switch holes in the Talon. I had already used a regular Clarling housing to adapt my winch rocker into the hole by the headlight switch but was never really happy with how it fit in the hole. This adapter solves that. Has texture like the dash and looks right at home. Places the switch out flush as it should be. Great little piece for $12.99 shipped.
Honda Talon 1000 Oversized Switch Adapter for Live Valve Blank! Talon 1000, X, R, X4
49302123842 4aa3276ff9 c
49301908421 15eeb3c20b c
The switch as I had it mounted.
49302123597 5b5fdb002a c
The adapter fits perfectly in the hole.
49302123452 c2960efa4d c
Switch fits flush like it should.
49301421503 a3743bd5d0 c
Code54
Code54
585
635
Hurricane West Virginia
Funny you mentioned that - I JUST ordered the plate a few minutes ago. Perfect place to put the winch switch!
Reactions: TerryH
67,697
Sweet.
Thanks for the pics. Looks good.
Ya, I bought maybe a dozen different adaptors looking for the right one. Some were close but none fit like I thought they should. This one does.
Reactions: TerryH
TerryH
TerryH
664
2,241
Springdale, Ar
Sweet.
I modded a Carling center adapter to get the winch switch mounted but as you can see, the switch was too deep in the hole. Yours is perfect.
TerryH
TerryH
664
2,241
Springdale, Ar
Couple of ride video's from the New Year's Day ride at Buckhorn OHV trails in NW Arkansas. 26 machines working our way thru the trails. It was a very fun day.
TerryH
TerryH
664
2,241
Springdale, Ar
Couple of projects for today. Project #1 was to get the Samsung Galaxy tablet in the Talon. Samsung had them on sale a few days ago for $119 so I couldn't pass it up. Bought a cheap mount and case on Amazon. $170 in the whole setup. I don't ride without Cheryl so I mounted it to the dash right in front of the passenger. She loves maps and navigating so she'll love it.
I drilled out the base and used 4mm stainless button heads to mount the base. 4 big fender washers on the back side for some additional support.
49329713561 da2312af00 b
The iBolt mount was $30. Seems decent. Guess time will tell but I think it will work fine.
49329242723 fe933d8147 b
49329242903 eee55b0027 b
49329933112 977e835128 b
49329933517 183cdcb1a2 b
Project #2 was to replace the Honda gear bag. As many of them have, the zipper broke. I did not want another bag so I returned it to the dealer for store credit. Opted for the Tractor Supply 32" box that several others have used. Nothing fancy but seems like it should do the job. My TSC only had one and it literally looked like crap. Covered in bird poop and generally a bit rough. They gave me $20 off. It cleaned up fine so all good for $59.
I picked up 4 D rings from Harbor Freight and mounted them on the box with more stainless button heads. I ordered some nylon straps with clips similar to the Honda bag so the new box will mount in the same way to the same points on the Talon. Won't have the straps until Monday.
49329237673 2c1540a7d0 b
49329928512 85ba12a44e b
I did not care for the TSC emblem so drilled out the rivets and filled the hole with more button heads. The box fits great in the Talon.
49329707161 2df61bd9a6 b
I used some foam weatherstipping I had on hand to help seal the lid. Nice that the box holds much more than the Honda bag.
49329928387 2475fb1ed2 b
Now to decide if I'm going to put the tail gate back on, go with some different type of bed extender or just leave it as is.
49329237023 eb5b8e54b4 b
Reactions: Landman
RideRed85
RideRed85
61
80
WV
Aw man, I thought the TSC badge was a nice touch :D.
Reactions: TerryH
Code54
Code54
585
635
I am using the same box (WORKS GREAT). What cooler is that you have? Looks like it fits perfect. Looking for something I can shove a sandwich and few things in when we ride.
IMG 4783
Reactions: TerryH
TerryH
TerryH
664
2,241
Springdale, Ar
Reactions: Sheetmetalfab
