P1000 The Beast
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Did I mention I cut zip tieso_O...
IMG 0322
& these are just a small number of what I had from multiple installs of various mods!
IMG 0323
Continued removing old wires and sound cables:(
Eltobgi
Eltobgi
4,599
15,186
North Dakota
With almost all old wires removed time to run front speaker wires...IMG 0325IMG 0328
Start wiring sound cables to amplifiers using Y splitters to run multiple amps front one sound cable...
IMG 0326
Eltobgi
Eltobgi
4,599
15,186
North Dakota
IMG 0331
Hooked up Rear speaker wires, Rear amp sound cable, and decided on location using the bar I had the SSV module mounted to, 1 on each side.
IMG 0333
:eek::eek: What a mess!
IMG 0334
Cleaned all connections removing dirt and corrosion and used a little di-electric grease on them.
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Before getting to far have to adjust settings and Hi Pass Filter... adjusted both Kicker amps:)
IMG 0329
Getting all wires and cable ran and tucked away
IMG 0336
And pulled wires through dash switch panel opening to finish positioning amps.
IMG 0338
Looking a lot better!
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Now for this mess...
IMG 0342
Bet you thought I was done, lol. Nope not even close!
IMG 0343
Removed Speaker Box and set off to the side! Has to be re-wired!
IMG 0345
Pulled wires down through access panel to aid in running wires back! So at this point you would think all zip ties were removed. Right?o_O Nope, Still a few hidden and pissing me off!
Forgot to add at this point skid plate has been removed, more zip ties removed, and have climbed under the machine, pulled wires, climbed out and pulled and untangled wires about a dozen times! Thinking about quitting:(
Eltobgi
Eltobgi
4,599
15,186
North Dakota
IMG 0351
Tough part is over now to run wires up and replace zip ties...
IMG 0352
Ran wires up along side the gas tank, &
Using these Kicker speaker wire covers here...
IMG 0353 IMG 0355
A shot of the wires from underneath! Used the air intake to keep speaker wires and sound cable from sharp metal!
Eltobgi
Eltobgi
4,599
15,186
North Dakota
To be continued...
Tomorrow I will rewire subs, and make the pvc speaker enclosures to mount into the cup holders!
156,800
Lol, been there before! It always looks like a cobbled mess of spaghetti when you're routing everything. You can tell by the amount of zip ties that you're doing it right, nice work Eltobgi. Makes you ask yourself 'why am I doing all this stupid sh**', until you power it up and tune it, then you remember why...clean, raw power! :D
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
Hey, wake up! :rolleyes: We need to hear this thing!o_O Play some disco. KC and the sunshine band - Get down tonight :)
I knew there was something about you I would like!! Disco rules!!! Also a fan of da funk. Not that crap soft funk either. I'm talking the nastiest of nasty funk. Play date funky music white boy!!!! Or brown or black or whatever is the case!!!
39,079
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
Secret service! Good one.
I am about to run number four Gauge jumper cables to the rear winch, you think I could get some of the stuff big enough for that?
Heck yeah. I've seen flexible conduit as big as you need at Lowe's. It's really tough stuff plus I like not having wires on rops to snag limbs and stuff.
Windrock1000
Windrock1000
2,539
9,663
Windrock, Tennessee
Check advanced auto. They stock #2 wire in the back. Last time it was about the same money as the jumper cables for me.
