P1000 The Beast
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Will probably run to Walmart tomorrow and pick up a few roles of double sided Velcro to reinforce a few areas. I still have pieces of old soft top from the popo that could be sewn together with Velcro as a patch to clean up the look.
BWAF
BWAF
I get paid to pass gas
8,857
42,437
Carthage MO
Looking good I haven't decided soft tops or build my own full door
Reactions: Eltobgi
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Last year I almost had a set of full doors at an unbelievable price, but the guy had just sold them minutes before I contacted him! Oh well, it wasn’t meant to be!:(
BWAF
BWAF
8,857
42,437
Carthage MO
I don't ever see used doors down here I may try to build some
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Looks like you've been working hard buddy.
I think the biggest downfall of the Honda is the round roll cage that makes getting a full cab much more difficult than the polaris or can am design roll cage.
Looks like you did an awesome job getting it all to work.
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Thanks! Not done yet. Although it’s not visible from the outside it will drive me crazy to leave it like this. It seals pretty well, so it’s not a bad design, it just needs a little more attention on the design which wraps the front ROPS.
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Decided to perform an inspection on the Front A-Arms and discovered the front upper bolt was seized in the bushing so I tore it all down cut the head of the bolt off and removed it so I could remove it! She was a b****!
8B275975 C79C 4CEC 8311 9DF526B755C1 BE67871F B3F9 4BFE A4FD 7783647F3CF4 44364EDA 1CCE 4E66 9107 6E310C06F7FE
Still seized after removal!
83108B29 9D88 438B 94D6 8A6F7D071B69
Precision ;)
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Also realized that I had a torn boot on my lower SATV ball joint so I removed it, cleaned it and reinstalled. I will be reaching out to SATV to see if the warranty covers it.
9499416B 534E 4C80 BB6D 6E28E2D6D3EF BBC98A9B A4AC 4492 B03D 741B130B7666 06F8DD6C 5EA6 417D 8E77 B44A91E8A642 C5469411 BA2D 41B8 8F4A 720E62C9A2BC
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Ordered these up...
AB5AE908 3F43 42CC 9DF1 B584EFCE09F5
EBF12FA3 F8A1 4B32 A548 062D56B9FFE7
B4E0DB2D F131 47C1 8741 DF3C663FBD50
I’m curious if they are an exact replacement same as what comes with new a arms or if they a higher quality aftermarket parto_O
13,350
64,939
