Mkmcdnl
Mkmcdnl
39
141
Osburn Idaho
Been trying to burn some old ear corn to clear out the corn crib. Load up some buckets and haul them around to the fire pit. Old washing machine tub let’s it burn low to nothing. It’s dark when I get home from work but the weather has let up a bit it’s nice to hang out at the fire for a bit.
So forgive my ignorance ,grew up in Oregon. What is a corn crib for.
lee
lee
Village Idiot
2,327
13,031
Springfield Ohio
No problem.
It’s an old school way to store corn for a year or so.
At the small end of the wannabe farmer spectrum it is possible to use the methods from 80~90 years ago.
Low cost but high labor input.
I started out buying corn from a local farmer to feed a couple of cows (steers but not splitting hairs to explain what a corn crib is).
Built a wood storage bin and the mice moved right in.
I wanted to grow the corn myself so my dad helped me build a corn crib.
He added 1/4” hardware cloth (wire screen) sandwiched between the frame and the slats to make it rodent proof.
Dad grew up in Appalachian Pennsylvania farming with horses in the 1950’s (using horses due to poverty not religion).
I ran out side and took a couple of pictures:
Out side the walls are slats and the top overhangs to shed water (it’s raining now).
E29B5CB7 BA97 41FA 8DFC 5361E9AF0A0E
Shed on the left is the Pig Palace and the shed on the right is the cow house
Inside the ear corn stays dry, leaving the corn on the cob promotes air circulation.
Corn will keep like this for several years - until the bugs get to it.
Getting a lot of bugs so I am burning the corn, haven’t had animals for a few years, with my kids moved out the freezer doesn’t empty out as quick.
A1813B81 602B 4431 A543 7156B21AA3F9
Edit: having a SxS would imply I could afford to take the wife out for a steak once in a while.
My wife has gone several rounds with cancer and she wanted better control of what chemicals we eat.
It gives her peace of mind and I get to collect old farm equipment.
Splorin
299
838
Maine
Love the schoolin! Seen the crib structures before but didn't know 'why'. Snow pics are great too. Locker is pretty much a necessity for deep snow runnin. Biggest advantage is reversing so you can re-ram farther and stucker! And no post run clean up.....
Red500
Red500
5,184
56,257
Greeneville, Tn.
Padded the side rails
KIMG0975
Moved my tag and mounted tag lights (haven't wired them yet)
KIMG0971
Mounted fire extinguisher (cause sometimes I Ride with popos)
KIMG0969
Fixed the rear-view mirror to give a better view and so it doesn't shake as much
KIMG0974
Tried for four days to ride some but never made it.
papermaker
papermaker
133
586
Lewiston, Idaho
11,301
83,894
The p500 is going to have a nice Christmas!
An EXELLENT combination. Santa rocks. It will be a totally different machine. Plenty of help here for any installation questions. Which diff oil are you going to use. Saw some comments about hypoid gear oil.
Peter_72
Peter_72
792
6,526
Louisiana
It’s a torq locker and Tusk power steering kit, my wife is excited about the eps and I’m tired of having one front tire in the air spinning (covering us with mud) as I get stuck! I’ve read a few install posts on the esp but I need to read about installing the locker. I also need to do some research on which diff fluid I’m going to use, I haven’t really looked into it yet.
J80
J80
36,869
362,197
WNC
I installed the torq locker and the gear oil I used was mobil 1 synthetic 75W-140 and it seems to be good and it made the diffs less noisy which is a plus
11,301
83,894
One heads up about the locker install is the 4wd sensor wire just pulls off, don’t try to unscrew the sensor. You might twist and break the wire.
11,301
83,894
Front mudbuster fenders helped. Keeps the doors cleaner.
Reactions: Backwoods and J80
Peter_72
Peter_72
792
6,526
Louisiana
Thanks for the heads up because after watching Jason’s video I would have unscrewed it.
Reactions: J80 and Mudder
Peter_72
Peter_72
792
6,526
Louisiana
I decided to start looking into the headlights on the p500, I haven’t done much riding at night until lately and these things are horrible! I figured I would start by seeing what kind of pattern they have on a wall......they definitely just through them in at the factory, this is only 5 feet away from the wall, the further you back up the worse it gets. Here’s some before and after.
8B528D2A 6978 424C B343 4D7E3C2C37B6 F72E71A9 7C37 4214 82C7 F199A02D1989
