Been a while so I figured I would update.
1st item-moved intake back outside of cab, great idea in theory.(too loud)
2nd item- added wipers to the SATV windshield
3rd item- installed an inferno heater
4th item- installed 3’ RGB whips
I used the factory mounts and drilled holes in the super atv windshield. I installed 1/4” rubber grommets under the mounta to isolate vibrations. I would recommend tack welding the caps on your prop shaft. You can do a search in the forums for more info but it is the #1 issue with Talons and I wish someone told me about it right away.
Have fun!
Sheesh…been a while since last update. I have installed spike upper doors, honda factory glass, and now working on a custom wiper setup. Once that is done it will be on to power adders….AKA Turbo. I suppose I should mention that this Talon works all winter! 72” hydraulic turn poly plow that clears an apartment complex all winter long.
