I would do it again. It was $53 from Amazon and I have enough to do the entire cab. front/back/driveshaft tunnel/underside of roof.what were the results of the sound mat? was it worth the time and expense?
Would you mind posting a link to that? ThanksI would do it again. It was $53 from Amazon and I have enough to do the entire cab. front/back/driveshaft tunnel/underside of roof.
I used the factory mounts and drilled holes in the super atv windshield. I installed 1/4” rubber grommets under the mounta to isolate vibrations. I would recommend tack welding the caps on your prop shaft. You can do a search in the forums for more info but it is the #1 issue with Talons and I wish someone told me about it right away.I just picked up my 21 1000X LV yesterday. I'll be taking notes from alot of your mods. I really love that thin sleek lightbar.
Which Mounts did you use for it?
Sorry for delay. Search Matt 66 on amazon and it will pop upWould you mind posting a link to that? Thanks
