P1000 Cooling fan overide
Ohio4x4
Ohio4x4
I brought the dishwasher
1,496
15,042
Swing and a miss, @Ohio4x4. @Remington and I are good, live just down the road a piece from one another and have also shared non-public conversations. We're disagreeing about whether or not disabling the fan will make the coolant heat faster, etc.. Just because I disagree with him on something doesn't make anything condescending.
Oh, and he made a comment about furnaces and thermostats that wasn't accurate, so I pointed that out. Sorry that YOU can't deal with that.
His comments on the furnace are factual. As a fellow professional hvac tech I understand this statement. Thermostats are not modulating they simply are on and off. As for me not being able to deal. Thats not the case I could care less about your need for attention. There will be no arguments from me good luck with that.
108,146
I do all my own furnace and AC repairs myself
the flame rollout limit switch tripped a few times in just a couple days, so I grabbed the new one I had in my box of replacement parts and got that taken care of
Thats why I cringe! you prob dont know the reasons the flame rollouts trip and just replacing it hasn't salved the root of the problem?
Thats ok, this type of stuff is what keeps me employed and my business profitable. Carry on!
Scoop
Scoop
4,278
16,031
  3. Talon R LV
How is "Are you one of those customers I have that when the system cant or isnt keeping up, you turn the thermostat up higher Thinking it will blow hotter?" factual? I'm NOT "one of those customers", so it's NOT factual.
I didn't ask for attention. But thanks!
Ohio4x4
Ohio4x4
1,496
15,042
This is exactly the kind of customer. Then when charged good money to share my knowledge and training to correct a true issue and not just the symptoms caused they act like the technician is a scam artist. Keep throwing parts at it my man im sure eventually youll get to the root of it without truly troubleshooting the system. But hey if you want to talk hvac I'm happy to help.
Scoop
Scoop
4,278
16,031
  3. Talon R LV
Heat exchanger is good (was replaced not long before we bought the house) and vents are clear. If these were causing the flame rollout switch to trip, they would cause the new one to trip as well. Sometimes, parts wear out.
I learned most of my HVAC stuff from my best friend of ~20 years, who also happens to be a professional HVAC tech.
Scoop
Scoop
4,278
16,031
  3. Talon R LV
I'M not that kind of customer. THAT is my point.
Scoop
Scoop
4,278
16,031
  3. Talon R LV
What does your HVAC lack of expertise have to do with the original poster's problem?
My post clearly stated that disabling the fan switch on the P1K won't make it heat up any faster.
I then asked what temperature the engine coolant has to reach before the fan comes on, but nobody seems to have an answer.
Someone else, not I, took the tangent to the HVAC conversation. Therefore, I suggest you ask him.
Mopower58
Mopower58
CST is the Best!
71,650
655,270
Crystal Springs,Ms.
I had a response ready for you but the original poster doesn't deserve it.
J80
J80
36,870
362,211
WNC
I hear that if you cut the fan switch off and get out and blow on the radiator it will heat twice as fast.
160,062
Oh Gawd, here they come!
Swarm
