CP’s Talon Rebuild
JenElio
JenElio
82,862
718,187
Loxahatchee, florida
And this is what I was going for. Plenty of sound, place to keep sunglasses and phone all safe and added three switches that’ll turn on whips/speaker and rings/ exterior and headlights internal rgb led lighting. It’s all going to be tied into one another so figured separate on/off for each system. Will have separate occupant lighting and door as well which I’ve always really liked in the Pioneer.
Got a little trimming to do, add speaker boxes then fiberglass over. But it fits nicely up inside.
That's BA CP!!
@TerryH might have something on this, not sure if it's a site contributor though.
I just found one on eBay kinda like what I’m looking for this morning but it’s not cut all the way out, these are recessed and painted. I’m hoping to find one cut all the way through. Was hoping someone here made them already or could. I sent him message to see if they could do it. Got something I want to do😉
0B23A290 9340 4E2F A125 0281EDCD75BA
5,759
26,451
Here's Terry's post -
Man he’s got that thing tricked out. I’ve always liked the old Odyssey colors he chose!
The backordered trailing arm showed up today!🤗
Partzilla got it to me in two days after they received it. Home at lunch, don’t want to go back work lol. Got something to do tonight.
122AA215 DCA4 4C8B A2E4 E14818B04541
highpocket74
highpocket74
2,173
7,205
Kinder, Louisiana
www.10-80dirtsports.com
If memory serves @highpocket74 of 10-80 dirt sports was working on something. There was definitely a thread about a magnetic plate on here not too long ago anyway. Not sure which model it was for though.
My dash panel is steel for magnetic mounts and solid, not cutouts. I could have something custom made for you if you'd like. Send me a conversation if this is something you're interested in.
TerryH
TerryH
664
2,241
Springdale, Ar
Austin at Razor Edge Design SXS Accessories can custom cut whatever you want. His stuff is all powdercoated steel.
Thanks for the kind words. It's been a labor of love but some days I wonder what I was thinking. lol...
That really is a labor of love and everyone can tell. It’s been one of my favorites long before I entered the talon ring. A lot of work you’ve done!
Hey thanks for the info. It looks like @highpocket74 is in the works of this little project. Hope I wasn’t a bother to him but he can do exactly what I was looking for😊
5,759
26,451
Makin' s*** happen is how he'll make his mark, kudos - 👍
Now that the trailing arm showed up the rear is back together. Everyone lines up and no evidence of foul play. Thanks @906UP and @GPR1500SC was finally able to rehome those parts. Also thank you @HondaTech for the suggestion on the trailing arm brace, it worked perfectly and gives added piece of mind.
A7D84CA3 CDDF 4C8A B388 BC86C643F3FB
27AC67F4 EF1E 4735 9752 61876A7D4B02
9F53A451 9FFE 4CFC B370 87C38E44BCC1
Ok complete transparency here. I like RC trailing arm braces but they are a f***n pita to put in😳 didn’t realize it from driver side because it was already torn apart but now doing pass side which includes tank, dash/rear intrusion bar and suspension removal, not to mention any plastic around, it’s not fun to try to do quickly. And if front bushings do wear out I think it’ll be back to it. And they use odd sized bolts so you’re collection of tools strewn around the place is staggering.
Ok b****ing over. After an already long day I came outta that a bit hot I’ll tell ya. They are well built and I’m positive they’ll do the trick. Worth the time.
73AAE05A 84D9 4616 BF03 30577ECD7B10
Mopower58
Mopower58
Unburdened by what has been!
88,349
756,066
Crystal Springs,Ms.
Ok complete transparency here. I like RC trailing arm braces but the are a f***n pita to put in😳 didn’t realize it from driver side because it was torn apart but now doing pass side which includes tank, dash/rear intrusion bar and suspension removal it’s not fun to try to do quickly. And if front bushings does wear out I think it’ll be back to it. And they use odd sized bolts so you’re collection of tools strewn around the place is staggering.
Good job!
