CP’s Talon Rebuild
Making the Talon my b**** today. It’s gunna listen🤣
There’s about 25k ft pounds on it now.
0BF72DAD 4280 4E7D A0E6 2C0CEAE96A94
C75A25B6 2E72 4C9A 9F64 AD748195B7C6
0779B57F DA37 4BE9 92A5 51DE272195F1
C09B8E07 074B 4E74 BF78 7915B4B27352
Currently waiting on parts. As far as I want to pull everything till the frame section shows up. Pulled everything with the old cage so didn’t twist the new one.
New front section of the cage now easily bolts in at three corners and is very close on left front. Cross measurements all show on the money and dash holes all line up for the first time. Rear cage section was down and forward a bit, not surprising, but now looks good. Steering wheel is straight and centered on driver seat. Suspension all sits uniform to the frame rack and cross sections under frame all match.
As far as I can go till the Brown truck show up.
E13F51AE D6ED 4316 852F 0ACDE61F4192
12835B04 86D0 432C 89E0 241FCB69766B
Buggyman
Buggyman
47,937
376,108
ne. ohio
New front section of the cage now easily bolts in at three corners and is very close on left front. Cross measurements all show on the money and dash holes all line up for the first time. Rear cage section was down and forward a bit, not surprising, but now looks good. Steering wheel is straight and centered on driver seat. Suspension all sits uniform to the rack and cross sections under frame all match.
you da man. looks really close now, amazing what a little friendly persuasion will do.
What did you ever figure out about the shock that was leaning?
I have no f***ing idea to be completely honest. After I got rear suspension in and dropped it she was half as far off as previous. I forgot about it when I went for a quick rip last night and I didn’t look again till it came on the frame rack, it looked identical to passenger side. It was way off before but no live valve idiot light or anything ever, good now, idk.
36A354DF A747 4589 87FE D699533F03E2
I'd be interested to see what the computer is reading on that corner vs the other 3.
Front ROPS is now Live Valve Blue. There went another 20 min of something to do running out of crap. Come on parts!
78E63A06 C4BB 4084 BF82 3D4F86322853
Is it enough to cover what you need?
I had to trim a bit more off the ends to get it to fit in the box.
Hoping the fender made the trip unscathed.
Yes it’s more then needed. Damn nice job marking it from measuring spots. And yes that’s the nicest fender I have by far! You’re a damn good guy, I owe you one.
Those measurements aren't NASA rated, so I'd check everything out before cutting anything.
I was trying to include standoffs for plastics and such to make it easier visually to see where it fits.
Ya you did good
NewHere2
NewHere2
Village Idiot In Training
55,950
395,938
High Plains of SD
Dang, ya got a good start on that thing !!
