CP’s Talon Rebuild
319,913
Couple developments. First one I haven’t wanted to talk about but is what it is and all know I will report the good with the bad no matter how much I like or dislike a machine.
My machine has the dreaded low bang😢 I noticed it not long after getting it built. Was very quick to get shift gate in and make sure cable adjusted correctly. From day one I knew this existed so always made sure it said “low” I can say very honestly I’ve never rushed the low shift, and pretty damn positive my family hasn’t either, not like we’re uninformed.
First time out it happened once then not for a bit, then happened to my daughter (some in i4wd slip video may have heard it, people say she let off and that’s why it slipped, she let off because it banged) it’s slowly progressed. Since I even ground a bit out of shift plate at low setting. Unfortunately I didn’t buy as new so who knows there but it was a dunes machine so I kinda doubt it was used much.
Well anyways mine is slightly different then other cases, it shows “L” instantly and easy like it should, but usually after it’s in and several hundred feet up trail it hits. Hard to gauge it that way. I’ve tried easing into throttle, jumping on throttle lightly and back off before going, pretty much everything but it still will do it about 1/3 time for no rhyme or reason, under different circumstances each time.
So the good news, I’ve been running last few trips in high range and am very impressed. It’s sooo much better in high range then the Pioneer that it hasn’t rendered too much an issue. I think between lack of weight and stock tires it does well. Worst part is following pioneer through very tight woods at such slow rate, it’s at verge of slip and lightly chattering clutches on occasion until I bump r’s it or stop and increase distance until can run slightly faster. Not trying to burn up clutches but not too afraid if it means continuing to ride.
Will be ordering ’22 Talon goods this fall and getting everything fixed but I’m little strapped for cash and can’t make time currently, I’m not allowing this issue to effect ridin season nor will I park it. I truly love this machine so moving on, hopefully clutches hold out, next few weekends have some massive climbs, and log crawls, little concerned bit f*** it!
319,913
Second issue I’ve had was bang on heavy bumps. It’s slowly developed over last two rides, I checked bolts throughout and everything tight so continued on. But it’s bugged me, tonight I set out to find it. As I was looking it over I noticed the rear sway bar went up hill to the shock and immediately remembered the rear sits lower then my friends, we’d noticed on a ride. I smacked rear spring and sure enough it sounded loose. Not enough preload, springs settled. Dammit I should’ve been on that quicker but not even 6 months riding I wasn’t expecting that. But she’s now got 2700 miles on it and ain’t been nice to her so ya no s***. Easy fix.
Oh and btw I really am enjoying the Live Valve, may feel different when there’s a problem but I’ve driven stock and LV on same terrain one after the other, it’s a totally different machine.
0DE57A49 2469 432F 8C47 89DECB903201
319,913
Tuff Luck Brother. Hpoefully it makes it to winter. It being a fixer upper, if that's the only bad thing to happen you still came out great IMHO.
WB
Oh I’m not complaining just reporting! I think for the difference it can probably afford a few things fixed. As long as clutches hold on I’m sure sub trans will. Really enjoy this machine! Hoping to ride soon with another one (wink wink)
319,913
Well I think the machine has had enough of those dirt road and Jeep trails🤣 Man last weekend was really really hard on the ol girl. At this point none of that matters anymore, not exactly the machine that gets detailed up before every ride like some. Kinda bums me out a little but sure more fun to ride.
Mechanically she’s doing great. I’ve had two torn boots, the front a-arm is still drastically “arched” and it’s occasionally had the low clunk but after last trans fluid change it’s been much better. Was in low most of last weekend and I’m sure it’ll get me till winter so can throw updated parts at it. 2600 miles, most of which have been brutal but it’s doing fine.
38811398 0152 4232 9B3E 949335F31927
B86DC9E1 A7BE 4A25 BB6A 3A6583084306
E8C12AFF 59AB 47CE 9EB9 BA04E0DCAF50
9203FDEB 9BD8 42D5 8DDC 1FE74500539F
2706709F F416 4823 BB35 776D9A67229F
319,913
Last weekend was an incredible ride. Probably over 30 hrs behind the wheel and most of it night rides in the trails. Sunday night I led the whole time all the way through the orange trail which is strictly dirt bike. I must’ve pushed over 100 trees and some of that trail is off camber at about 50-60 deg so trees are all that saved you. Was only cut out twice but Pioneers behind me were cut out 5-6 times following. This machine really does well with no shots given. Really like it! It’ll be nice again!😉
4FB01A0F EC9A 4EEC B6FF 8915A95387A1
42D355AF 59F4 446F 8897 8518D25A87D9
07E134F3 BF99 4EBD A55F 825BAB41CDA1
4F0444B2 F211 4C71 8195 B60318AD4C1E
7443D0F1 4347 4750 87BF 7D9568087D41
325FD7A1 E056 49F7 AE58 E76E735AF95D
49E59EAA F0BB 4D33 A4EA FAA96EAD6B3C
1A86F489 33E7 438A 90F4 D27B534DB574
D231FE30 C2D4 499E 81A8 3623BE785303
A94A47DC 83D5 47DA 9CDA D3F021898CB0
FFF4B9C2 B2CF 4854 9022 5DE92F08F90C
8BB2D2B2 41A3 4236 8FA7 FD26E000E9E2
D1CBF13C 51E5 4591 8427 C17709A9FBA2
E9DA8888 3D12 442B BC24 F233CFC0253B
319,913
Oh and a shout out to Bosman Designs. Wish I knew his name on the sight but his stuff is exceptional. His bumper is taking so much more abuse then my friends Honda brush bumper it’s not funny. One corner got bent up but that was a very stubborn pine, the rest isn’t even really scuffed.
I recently pulled the lower doors and got sick of my phone bouncing out of the machine so called and Ryan answered, he said he’d send it out immediately if I purchased the phone holder but they shipping closed in 15 min. He had it boxed up before I paid him. And the phone mount made it for the weekend. That coupled up with the Quad Lock for my iPhone held up to even the windshield being pushed in be a tree🤣 seriously that guy kicks ass, thank you
4D2AF9E8 45ED 40BF 8932 95EB437D6B10
99B7B290 CFBF 4760 99FA A539D4A7DD9E
56,731
View attachment 352990View attachment 352991
Yep, I've got the same one and it's a quality piece. I have mine on the steering column because I was going to put the PV3 there, but I think I'll move it to where you've got yours and use it for my phone.
1662730332853
319,913
It’s awesome. With placement on side it’s been easy to control phone and face recognition unlock works flawless. The Quad Lock system is really good too.
319,913
How does your phone mount to it? Gotta pic?
It’s very secure. I got the factory case but they make attachments for any case or device. These are made for dirtbikes.
If take much video with phone they have vibration dampeners as well to protect the phone cameras.
C0FDDE8A 2EB6 4C90 8BCE 2BC39EE67B99
367D533E 540A 4C46 9871 24B061621C21
56,731
You need a case that has the quad lock adapter on the back like this:
1662734616198
You press that blue tab in CP's pic as you put the phone on and twist it. That tab locks it in. Used to use it on mountain bikes and it worked awesome.
Here's the Ram adapter for the quad lock, they are pretty proud of it...
1662735081249
56,731
Damn you @CumminsPusher .... I just ordered the case and mount to throw in my Talon. I have the tackform in there now but I like it better in the Pioneer where there is more room to take the phone in and out of it. Hopefully have that old yellow bastard back this weekend!
319,913
Really impressed with the case itself. I thought it would only be on phone for rides but it’s a much better case then I had so it’s permanent now.
319,913
