GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Just in case someone wanted to know what was inside a Honda tailgate.
Sometimes the best ideas come from insanity, sometimes not. Quick little project so we'll see how this one goes lol. No money after Xmas so I guess this is what happens. Going to bring in piece to work tomorrow to finish up real quickly.
Ooo ooo ooo...My turn... It's going to be... A new muffler cover? Or maybe the wings to your Batman outfit;)
322,785
I'm betting paint. Lol
Ya. I didn't want to paint my current gate because you need to get rid of the texture so it'll look good and I wanted it to resemble the panels on the side of the vehicle so I figured with this panel I'll sand and prime out all the texture and give it kind of a factory look I'm hoping
Tigermark
Tigermark
Outside looking in.
Keep @drfubar away from it. He'll spray paint it red with that rattle can.
322,785
Rattle can is fine for lots but I prefer a big gun as my hand is carpal tunneled to fit one lol. I've sprayed around 200000 cars so Im comfortable with the gun.
322,785
IMG 7958
IMG 7959
Also I figured the roof needed a little something so last night I smoothed out some of the texture and squirted the center I'm not positive if I like it yet I may go back but I still don't have my Honda decal for the center and that might just tie it in right like I was hoping. Hopefully this looks like a factory decal when I'm done
322,785
IMG 7964
IMG 7965
Got the rear panel sanded a little then scuffed heavily with alcohol (no @drfubar not your type) and primed up. The edges need smoothed out because this was just rough cut but I'm time limited today as we're busy at work so main objective was primer. 3 heavy coats butitll probably require another couple to get everything out and smooth. Gives idea though how bad it would look if texture was left.
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
View attachment 29866 View attachment 29867 Got the rear panel sanded a little then scuffed heavily with alcohol (no @drfubar not your type) and primed up. The edges need smoothed out because this was just rough cut but I'm time limited today as we're busy at work so main objective was primer. 3 heavy coats butitll probably require another couple to get everything out and smooth. Gives idea though how bad it would look if texture was left.
Loving that man! Looks way better without texture imo. Did you have to cut it up like that or do you have something else going on? I'd love to make one out of aluminum one day. Stocker is so weak feeling.
322,785
Expanding foam makes it stout! Just fill up the gate. We could put an engine block on ours except for maybe the cables lol. We've had 3 people on it without snapping though.
No my gate was good but this gate was just sitting there so I figured I'd just cut it up. The rest of the gate will still have texture it'll kind of look like the doors with a added panel I'm hoping. Someone could cut center out like this then foam and glue back though
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
That's gonna look good when you get er done. What's your plans for reattaching it?
322,785
Probably just two-sided 3M tape that'll hold about anything but I wanted to bolt it on using hex bolts like Honda does but theyd stick out I think and look funny but maybe even a combination if it looks to be ok
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Use those nuts that sink into wood when you tighten them and some flat cap bolts countersunk.
322,785
That sir might just do the trick on the lower corners
The upper has access behind the gate for a covered head nut so I'll see if can find a stainless hex head for both. Good thinking Delton I like it!
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I bust off a decent idea every now and then lol
