P1000 Jackal's P1000-5
68,378
I would like to see pic of mount points @JACKAL.
Figured bottoms just mount like standard. How about tops?
283,294
On both sides loop around each side of the headrest one full round like this:
20160818 185845
Then bolt on like this for drivers side existing hole is already there just stick a bolt in it:
20160818 185858
Passengers side drill hole through both layers of bracket in same location and use the longer bolt as described:
20160818 185913
Sorry for reflection hard rear panel glass messing with camera.
283,294
Demonstration???
I don't do selfies, but do model SxS destruction on occasion up to you to have camera rolling.
I can tell you I had these exact restraints in a RZR 800 and held us in place injury and pain free until we stopped on our rooftop.
Reactions: ohanacreek
Dan1960
Dan1960
25
17
White Pine, MI Upper Michigan
Ok so for the heatshield install I removed the seat bottom, seat back, and the plastic that spans the gap between the two.
All stripped down looks like this.
Fitted front and side edges leaving 2" material tucked down front and sides held by OEM push rivets. Trimmed back and passenger sides, left center full length to fold down in back to double thickness between engine and center seat.
All tucked in place.
Center plastic piece back in place.
Seat back in place.
Bottom back in all done.
To check sub transmission I cut out a 8"x8" flap then took a scrap piece 3" longer and wider glued to top of flap. Simply lift up to check oil level then let it rest on top seat holds firmly in place.
Material used was this:
ESP Low-E® EZ-Cool Car Insulation Kit(Includes 40 Sq. Ft Insulation, 10' Foil Tape): Heat and Sound Automotive Insulation For Your Car Restoration Projects - - Amazon.com
Enough for two machines for $33.
Nice Job, too bad you don't live by me I would pay you to do my machine. I did buy the piece that just goes under seat and up the back a little bit. It helps, but still get heat in center of seat. If Honda doesn't do something soon, I will certainly do what you did to mine. You might have said, but how does it work? Thank you, Dan
V
vitulla
11
Montreal, Quebec, Canada
Hey Dan
I can't comment on how well it works, but my cousin has his and after his first ride we put that material under the seat and although it did help, it did not cute the problem. The heat was coming right through the back crack. I just got my 1000-5 Thursday night and right away tore it apart and did the entire seat and back as Jackal did. It will be a good comparison as I'm riding with my cousin on Sunday. I'll let you know but I'm hoping it does a lot better then just the bottom. The whole project took me about an hour and a half, that's taking my time and going really slow.
I ordered the same product that was shown in this thread of Amazon.
Hope that helps a little
Danny
Eltobgi
Eltobgi
4,599
15,187
North Dakota
@JACKAL, those seat belts would be ideal for my wife, as she is always complaining about the passenger seat belt! However, the wrap around the bar prior to being bolted to headrest, one being higher than the other would concern me. For example, would the lower wrapped strap in the event of a front impact stop movement more quickly than the higher resulting in more force initially to the lower mounted strap contact point of your body? I would imagine straps mounted level would be safer! I'm not an expert by any means, but am interested in hearing comments by all.:)
Tramguage1
Tramguage1
Texan
7,608
31,547
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Now that I am going on longer rides frequently got tired of the OEM setbelts rubbing on my neck / collar bone area and wanted something more comfortable.
Since I am completely happy with the BEARD 4 point restraints with automotive latch that I have in my P500, I added a pair to the front of my P1K5D. Keeping the center seat belt for car or booster seats for now.
Installation was very easy, on drivers side behind padded headrest is a hole already between the two mounting bolts. There I used a single 3/8" x 1.25" bolt to secure the upper harness mounts together to backside of headrest mount. On both sides used the OEM location and bolts for the bottom harness mounts. The passengers side top is a little different but simple drilled a 3/8" hole in the same place as on drivers side and used a 2.5" long 3/8" bolt due to the size and shape of the OEM metal headrest bracket.
These padded harnesses are VERY comfortable as well as keeping you put on rough terrain making the ride even more enjoyable. In case of rolling the machine these will keep you in place even if you end up on your roof.
Would like the model # of the belts you used. Are there tabs,and are there any adjustability for length at the ends?
Sent from my SAMSUNG-SM-N930A using Tapatalk
283,294
It makes a noticeable difference it heat and noise reduction. The bilge fan helps even more so you can tell when it is in order off according to the wife. The hard plastic center between seats sections barely even gets warm after extensive riding where it would be very hot after only 30 minutes before. The only heat I now notice comes through the range select lever opening much like a hair dryer on low, I never noticed that before because of the heat from the seat which seems resolved now.
Reactions: pct
283,294
The length of each belt is adjustable so the slack / tension is set once installed at mounting buckle ends. The individual rider quick adjust is the used for torso, and lap belt tightness. If the lap belt is properly adjusted it should hold or prevent verticle rider movement, the torso/ shoulder belts hold your upper body from fore and aft and side to side movement, with the padding they are comfortable. But feel free to devise your own upper mounting system for personal use.
For what it's worth here is how I mounted them in my P500 like you would want to, I'm just limited for now and the P1K doesn't have an easy way to do this while being mounted centered for each person.
P500 - Jackal's P500
Reactions: Tramguage1
283,294
283,294
Just ordered me some. Lol.
My wife has been begging me to get these in the P1K since day one she likes them that much from the P500 and SXS before that. We have worn them for up to 10 hour rides out West and they are comfortable, yet safer than the 3 point belts. The key is you don't get jostled around in rough terrain they keep you planted as if you are a part of the seat bottom if set correctly, wear them loose and that effectiveness is defeated.
283,294
I'm going to start asking manufacturers for referral fees. :D Put click this link to buy this accessory in my threads. LOL.
Someone has to be the Pioneer of modifying Pioneers living in Pioneer, TN. :p
Tramguage1
Tramguage1
Texan
7,608
31,547
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
PM me your address and sizes and I will send you and the wife a T-shirt with my companies logo!
