P1000 Jackal's P1000-5
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
All winches should feed from the bottom, that is where they are designed to pull from. I agree the angle could be less, for the guy that uses his winch only every so often I don't think it is a big deal but for the guy who uses his winch for a snow plow can definitely cause premature wear on the same section of the cable. I don't use my winches often, they are insurance for my style of driving, that being said my cable will likely dry rot before I wear it out over the fairlead, but that's just me.
Thanks for the sanity check!
280,782
OK got all the mirrors and lights completely done, if nothing else at night at high speed I should be able to pass myself off as a meteor. :D
Pod lights are 18 watt 6 led 4" square each is 1,260 lumens on front and back angles out and down for night time orientation.
Rear light bar is a 12" 120 watt 4,300 lumen unit.
Front light bar is 40" 400 watt 32,000 lumen unit.
Some night shots; first no lights, then OEM lights, then OEM + Pod lights, then OEM + Pod + light bar in drive way with some ambient light.
From the Rear:
20160106 213723 20160106 213753 20160106 213818 20160106 213845 001 20160106 213906
From the Front:
20160106 214034 20160106 214056 20160106 214131 20160106 214152 20160106 214218
No ambient light, same sequence with a straight view then angled for each; first OEM lights, then OEM + Pod lights, then OEM + Pod + light bar.
20160106 214340 20160106 214351
20160106 214413 20160106 214432
20160106 214453 20160106 214503
And out back:
20160106 214542 20160106 214555
20160106 214614 20160106 214623
20160106 214515
By golly this old man can see in the dark now. Ready for Appalachia and its boogers, witches, & haints. :confused:
Dash rocker switch panel lights at night:
20160106 215041 20160106 215055
Tomorrow my Strong Made 2-3" lift kit arrives along with my 6+1 offset test wheel. Will wait to post pictures on Friday in the daylight for before and after with the lift kit. All goes well will order my wheels and tires.
Thank you. That really looks good
Rear light bar is a 12" 120 watt 9,600 lumen unit.
From the Rear:
View attachment 8729 View attachment 8730 View attachment 8731 View attachment 8732 View attachment 8733
From the Front:
View attachment 8734 View attachment 8735 View attachment 8736 View attachment 8737 View attachment 8738
View attachment 8739 View attachment 8740
View attachment 8741 View attachment 8742
View attachment 8743 View attachment 8744
And out back:
View attachment 8746 View attachment 8747
View attachment 8748 View attachment 8749
View attachment 8750 View attachment 8751
Lot of light looks good! Be awesome late night deep in the woods be able to see after a few beers.i like how you mounted the bar down low rather then on the roof. Our last rig was on the roof and even though it held up even though a roll over from my kid it always hit branches and just got in the way. Lights above your head never work as good as below. We had them turned off most of the time our 180watt on the bumper worked better. We will mount low this time for sure! Have you considered upgrading the stator at idle our 700 only made about 400 watts (I'm pretty sure the 1000 has the same output however it frees up a little because of the led headlights) but I had to send in the stator to Ricky's stators after that it added around 300 if I remember right and that finally held up other then at idle.I plan on doing that on the 1000 and just praying it'll be enough. Do those 3in housings work well with the bar as spot beams? We've always gone with floods as their light is spread out I was wondering how they light up as your driving
HondaTim
HondaTim
203
40
What brand cubes and bars did you go with?
Hometeam
Hometeam
1,034
4,359
Normal, IL
Jackal I couldn't totally tell from the pics. But did you mount your front lower light bar to the metal of the glass windshield? I am getting a curved led bar and was planning/hoping to mount it there also.
HondaTim
HondaTim
203
40
From the Rear:
From the Front:
And out back:
What brand lights are you running?
280,782
All the pod light 4" square are flood beams not spot, both the 12" & 40" bars are combo spot / flood. The lighting is awesome grand peripheral vision for turning in the dark and seeing what you are turning into.
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
Jackal, for your rear lights, did you run the wires along the roof or down in the body someplace?
280,782
Yes I mounted the light bar drilling two 3/8" holes through the metal of the glass windshield frame, had to use 3/4" thick nylon spacers between standoff and windshield frame for light to clear. Curved light bar may be better but the corners at the mounts may still be in the way.
Reactions: Hometeam
Oh they looked like spots on the garage door I must've been looking at headlights from the back that explains more I was wondering why spots. Looks good! Stupid amount of difference over stock:):):)
280,782
Used 14/4 multi conduit wiring for trailer lights all 4 wires coated in heavy black rubber insulation, ran it from under hood up front passenger side along the top of roll bar next to the roofline all the way back and crossed over the back roll bar to the drivers side. I could have use lighter gauge wiring but that's what the parts store had and I liked the extra level of insulation. 2 wires did both back pods the other 2 the 12" light bar.
Reactions: PioneerPete
280,782
All my LED lights are STV same as my rocker switches, price was right and all are CREE LED's with IP67 rating. the front 40" bar used 5w LED instead of the standard 3w that's why it draws 400 watts instead of 240.
Amazon.com Seller Profile: STVMOTORSPORTS
Amazon.com: STV Motorsports® Led Light Bar CREE 400W 40" Flood / Spot Combo 5w/LED - 32.000LM OFF ROAD: Automotive
https://www.amazon.com/gp/product/B00R2R3LYQ/?tag=sxsweb24-20
Amazon.com: 18W 4" Cree Led Light Bar Flood Driving Fog Light Roof Off-road 4X4 ATV UTV SUV Truck (1PC): Automotive
280,782
Well lookie what UPS dropped off this afternoon. MTX 46" Bluetooth FM 280 watt Sound bar with dome light built in and Strong Made 3" lift kit.
Looks like I got some more wrenching to do :)
20160107 163219
From the Rear:
From the Front:
And out back:
Jackel I was wondering do you get much glare off the hood. Mine is red also but I will be going to white and was conserved a little
280,782
No, but that is because the frame of the light bar eclipses the hood entirely, all I see is the black light frame and then the ground.
Awesome good to hear
chadbo
chadbo
Mama tried
2,044
5,659
Seminary , Ms
Jackal, hey Jackal , Jackal, Jackal, hey Jackal, Jackal Jackal Jackal...Hey lol you tired of hearing it yet. I guess that's what you get for having all the cool stuff:confused::p:D
280,782
Here is a few pictures of the Strong Made lift kit installation, fairly straightforward I think I had both sides of the front end done in less than 20 minutes. The rear was a bit more persnickety mainly because of the Trail Armor A-Arm covers limiting movement of my big hands. The photos shown are all on drivers side front and then rear.
For the front all you need is a 17mm Socket and wrench to remove the OEM bolt and a 19mm socket and wrench to install the replacement hardware with the lift brackets, and a 3/8" socket to tighten the u bolt nuts. For the rear in addition to the aforementioned you have to remove the rear wheels, and will also need a 14 mm socket and 1/4" drive ratchet to remove and reinstall the sway bar bolt and the lift brackets to it. The rear A-arms are a bit more difficult to maneuver and start bolts by yourself. If I had an extra pair of hands would have gotten it done in 1/3rd the time on the rear. Overall it appears to be robust and after taking it for a spin letting the suspension recompress and measuring it I gained 2" of lift in the front and rear.
Before, height of fairlead 20 1/2" to bolt, afterwards 23" to bolt:
20160107 163328
Front drivers side:
20160107 180410 20160107 180606 20160107 180617 20160107 180831 20160107 180840 20160107 181433 20160107 181443
Rear drivers side:
20160107 185413 20160107 185424 20160107 192317 20160107 192331 20160107 192815 20160107 192823
Will post up some before after pictures tomorrow of the lift kit.
280,782
STI HD3 14 x 7 rims with 6+1 offset, ordered one rim to ensure I had adequate clearance going with the 6+1 offset. Turns out is was about 1/2" difference per side in front and 1 1/2" difference per side in rear* Note OEM rim is 8" wide this is 7" so 1" of the 1 1/2" is due to the rim width difference in the back. Everything cleared front and rear should put me close at 61" front and 60" wide in the rear. I took pics of it mounted to the front as a test fit full lock to full lock but the concrete worms must have gotten to my phone. Anywhoo here is the rim mounted on the rear.
20160107 183430 001 20160107 183401 20160107 183417
So I will be going with these wheels on 28" x 10 x 14 Roctane XD tires.
Reactions: pct and Tot
