P1000 NBomars tinkering and silly stuff
nbomar
nbomar
4,416
17,854
Springdale, AR
Lmao.. pics??
I was talking with @Tramguage1 today about this. @Ragnar406 know I’m not really a strategy guy or a researcher. I’m more of a do it now (half asser) lol. I almost drilled a hole in my windshield last night just to get the antenna wire to fit. Lol. Glad I didn’t do that now.
nbomar
nbomar
4,416
17,854
Springdale, AR
4944242644ecb763e3703e0b23b3b53fB4ce23ff5c9f4f69666a8352c38dec82
Pretty sure I posted these somewhere before. You could use the front bumper too if you had height issues. That would probably work better for me also, but like I said a few posts up... not really a planner, more of a just get er done and figure it out later guy.
Ragnar406
Ragnar406
The Great Bald One
4,446
17,020
Bella Vista, AR
View attachment 62833View attachment 62834
That is an ideal location to put the antenna -
Reactions: JTW
Ragnar406
Ragnar406
The Great Bald One
4,446
17,020
Bella Vista, AR
I don’t think that would work for me..
if you are not going to run LED whips up your Back Rops I would look at how @ohanacreek mounted his antenna - it is lower and more protected from the limbs -
Reactions: JTW
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
I think I'll mount mine on the rear vertical face of my roof. The mounting point being a couple inches below the roof line. That way it will be up high but when branches come across the top they won't knock it off. Or if I end up wheels up it hopefully doesn't get broken.
Reactions: Ragnar406 and JTW
Mounting it to the ROPS should in theory give you a better signal, a metal roof would be far better.
Reactions: JTW
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Better signal due to height? My roof is 6061 aluminum. What are your thoughts?
I won’t... I’m a heterosexual!
I like that antenna position
Ragnar406
Ragnar406
The Great Bald One
4,446
17,020
Bella Vista, AR
Aluminum = no but if it were a steel roof then yes the roof would make the place to mount.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
What happens when it's mounted on aluminum? What if I have a bolt that goes through and connects to steel?
Ragnar406
Ragnar406
The Great Bald One
4,446
17,020
Bella Vista, AR
Honestly I cant remember - I know it was a well discussed issue (among Hams) when Ford went to the aluminum body. I seem to remember it had something todo with how different metals interact and more of a chemistry to paint thing rather than antenna radiating.
Antennas are something you really just have to try and fine tune. Of course a mag mount antenna will not work on Aluminum But installing the antenna as you say with a bolt that goes through - you should be fine.
Reactions: Cuoutdoors
E
elkguide
3,377
7,964
Vermont
I can't vouch for your sexual fantasies but since you spend so much time upside down.......
maybe you should reconsider that!
Reactions: JTW
E
elkguide
3,377
7,964
Vermont
Welllllll... are you offering to guide me thru it?
I've never played for the other team so you'll have to go "BACK there" yourself.
Reactions: JTW
allgm1
allgm1
1,049
1,484
New Hampshire
Let me get a meter on it and i’ll Let you know. It should be fine though. I am just not sure everyone is going to want to mount it like you did :confused:
I finally got a chance to put a meter on my set- up the other day swr was 1:1.25 with the mag mount on mine.
