Ragnar's Ride And Adventures
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
More to come but I decided to see what it would be like to follow in @GlockMeister footsteps and I started taking off my lift last night. Which is something I have been wanting to try for a while.
I had been riding with the Fox shock for a while when I first put on the lift... I initial impression was that I did not like the lift but knew I needed to give it time. Soon after I put on the SATV A Arms and went from a 28"/15" tire to a 30"/14" tire and the ride greatly improved. I have always remember the difference in pre lift and lift ride however.
So after reading the discussion on how shocks work (@snuffnwhisky @joeymt33) And talking to @GlockMeister about his initial experience I decided to take of my lift.
While pulling the front last night I noticed one of the holes on the lift bar had gotten wider. Oddly enough the stock holes it lines up with did not seem to suffer the same fate
IMG 4478 ...
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
No updates for a while - Met @my99svt & his better half yesterday along with a Rzr friend of ours to ride Buckhorn trails here in AR. They are adding in trails fast there and we did a little exploring.
97ABBF09 75FD 43FC 944A 0CD519B2772A 4DBC10CA 17F4 46D1 9047 9C443D182A84
No telling how many spiders I picked up... stopped at car wash on way home for round 1 of spraying and finished round 2 this morning. Still finding them dang it.
4DCF800E 4465 4992 B935 FD9F22FDA6EF
EA4E6254 E66B 456D B55B 17DF7FEF4BAF
Also found a water/mud hole that got deeper than expected ... it was up to the seat - when I saw my cigar box (that was in the underdash storage float over to the steering wheel I figured time to put it in reverse lol
69F7325C DD44 4E12 B916 BD51E58F9695
Fun day and weather was about perfect we got there just as the rain was stopping so no dust at all
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
Performed a little maintenance this past weekend.
1. Changed our the brake pads - this time going from Raceline back to OEM
2. Replaced a seal on the passage rear Axle - First pic is after I moved the Honda to provide more room to remove the axle in the garage
IMG 5549 IMG 5551
easy swap out
lastly it is looking like it is time to schedule a time to get weld washers installed on the top front A arms... the holes continue to get enlarged slightly as the nuts become loose despite using lock tight.. I had ordered 2 sets of new hardware so I went ahead and installed a set I really think that if you changed out to Super ATV A arms you should install new hardware - I can tell that the nuts (which are pinched I believe) just did not have the same tightness as the new nuts I put on this weekend. As a safety measure I grabbed some other M10-1.25 nuts as backup and installed as below (with Red lock tight this time )
IMG 5550
I have some Weld Washers that I will take pics of after I get installed
13,350
64,938
View attachment 152951 View attachment 152953
easy swap out
I have some machined washers and nuts/bolts if you don't like the set you have.
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
While I love riding at buckhorn I swear something breaks every time I am out there.. today was no exception .. riding with @my99svt , his wife and some of our Rzr friends I am leading the way when I hear a unusual noice from the drivers rear tires area... I stop and look .. see that the jam nut on my SATV a arm appear to have come loose.. no problem grab a wrench give it a yank and pop ... the remaining threads in the A arm expose themselves.
4468416E 7DDA 48D6 9680 BF71DA08FF94
No worry bailing wire to the rescue we winch me up on the side a little and I wrap bailing wire around it to hold it together... luckily we were 1/2 mile from some blacktop and gravel roads and made it back to the parking place . I will have to call super atv Monday to see about a warranty replacement.
F8674414 08DD 4E07 ACFE 62EE4C67D3B0
Ended up finishing the day by finally installing the attachment points for my wheel bonnets - took it for a spin down the road and like them so far
4D18EC8F 339D 4552 BF47 1E48470A817D
Got to get ready for next ride
BWAF
BWAF
I get paid to pass gas
8,857
42,437
Carthage MO
Hell of a day
66,315
Yea, but it was fun, If it was going to happen I would rather it happen today than on a out of town riding trip ... only downer was they have a new trail just opened that I wanted to try.. next time
Where did you get the wheel bonnets?
Reactions: Ragnar406 and BWAF
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
First time running front and back cameras - I ahd the back running off a battery pack so I was saving until we got to a later part of the trail.... and then my a arm broke and cut the ride short. However I did get a little footage that I wanted to see how editing worked.
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,567
Greenville, Mo
Gonna have to get me one of them fancy camera!
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
And we are back
11F76CD9 91D5 44F8 A6D9 29548F7F6167
I really thought the threads on the T’s had stripped out but it turns out that it was the threads on the inside of the A arm. However in less than a week I am back up and ready to go. I will say that after taking the T’s out there was a bit of water that came out of the A arm... I know @GlockMeister noticed that on a set of his A arms previously which is why I was checking.
Better look at trail Side repair
1F9BE59F 7320 45AA 8E4F B6CB8710453F
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
Well the holes for my upper A arm bolts were getting worn a little more. Big Thanks to @Neohio for the weld washers and bolts that he worked up.. I was finally a ole to get. A local welder to weld them on this past week - I really need to learn to weld. I took the Honda out this afternoon and it is nice to be solid up front again.
First two pics are a comparison of some other weld washers next to the ones @Neohio had made
3A3105BF 1A72 4F8F AA64 FF529C86A35F B2BF7F20 E414 44BB 960D B5E53C4E9201
Pic of the weld that was sent to me
681DF45C E42C 4369 A853 DA6EFEEAF639
followed by pictures of the final product
ECABDF30 F46B 4806 B0E9 DBE56CD3B227 1B2E4B40 A5A8 4DEF AA49 561076183D0D
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
After the overland trip I have a little tlc to complete on the Honda.
  1. Swapped out both Tie rod ends (one was very loose and the threads had gotten filed down so that I could not get any tighter - greatly improved steering.
  2. Need Front and back bushings replaced
  3. Need to replace the rear hub bushings - to which I was looking at Honda OEM first but went with Garage Products bushing kits...
IMG 6065 IMG 6067
I post up about the install after
Ragnar406
Ragnar406
The Great Bald One
4,447
17,022
Bella Vista, AR
Also a couple of pics from Sat and @my99svt getting into a little trouble... going up a trail he got well you’ll see below. Note that his roll cage was stuck on a rock on the drivers side preventing movement
38F0DF6B 314B 4376 9970 B985AF7AB8FA 01FDB4DF 8FA5 43DA 98BE EF7A6FCA4FE5 D5E0842B ECCD 440E 8D40 F1CC359745D1 D7FCCDCA AA9D 47BD B60F 8492BF4AA124 19DF7935 29CA 481A 9FD1 DFA099EAA685
that is also a steep bank getting down there to help him lol.
