My .02.
I run 7" wide 5+2 rims ITP rims ($40 each) and 2" wide spacers from Dungear on Ebay, these are USA made Billet with wheel studs instead of bolts like the cheaper china imports. I run 30" tall interco R-Force 8" wide tires. I am still just under 54" wide. It improved stability and helped tremendously. Get taller tires and go wider if you can still go on your trails without getting a ticket. If you dont want tall tires at least try to gain width, on the stock tires being 4" wider will make it feel a LOT safer.
Sure, I still fall over, but I do that in places where many fear to go and I could avoid falling over by just going around certain sections, but what is the fun in that?
Ruts are not as big a deal for me now, while I can only drive over a milk crate I find that many jeeps on the trail really cant even do that without the punkin hitting it. And the RZR's are belly draggers in comparison. I sit at about the same ground clearance as a $20k stock high lifter for under $9k all in. If anything I wish the P5 was longer. Ruts to me mean someone else has already been here, so why cant I go here?
I once asked some 1k RZR riders if they get scared and they chuckle... "No, not really", Well, I am not ashamed to admit that this P5 can scare the hell outta me when I let it, and that's why I love it! I don't keep the plastic on my furniture to save it for the next owner.
Think of it like JUDO, the best way to throw is to be thrown 1000 times... In this case the best way to learn to the limit is to know where it is first hand and be prepared! Falling over is not often as dramatic as some make it out to be, just learn it before you on a mountainside with no trees to stop the roll.. . Just be sure to shut the engine off immediately upon falling over.
Here I can be seen draining the water out of my cooler, it was after this trip that I discovered the drain plug in the cooler and that would have saved a lot of time...
