P1000 Stupid Air Cleaner!!!
0
0860silverado
964
1,862
louisiana
You mean like this??
Yes, it works awesome.. everything still looks new at the Honda filter.
Yeah! Thanks! And I know that my intake tube is air tight all the way to the opening under the hood because I can kill the engine by choking it at my under hood snorkel. I think I may replace my prefilter with a K&N. Another upside is that not only do I never have to go through the hassle of accessing the factory filter, but I'll save money over the years because these are washable and reusable.
Reactions: sharp and JTW
Yes.. make sure you buy a washable filter if you have it set up like mine. I don’t use oil on it and it’s done just fine
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Well the good thing about it is the fact that your air filter was dirty enough to need changing, so it wasn't for nothing! I bet you would've been REALLY teed off if, after all that, your filter would've looked almost like new! I wonder if installing something like a K&N cold air intake filter on the end of a snorkel would keep your primary filter clean enough to never change or even look at it?
I haven't checked my air filter since installing, but curious to see if my prefilter helped at all.
FB IMG 1505490401552
Bayouownbeer
Bayouownbeer
798
1,123
Chauvin LA
Easy killer! I had use long 1/4" socket extension and Allen tip for
My first removel. Now I just use the tee handle and Allen tip. You still going to mulberry this month??
Reactions: sharp
nbomar
nbomar
4,416
17,855
Springdale, AR
Yep. Next Thursday night I will be pulling in out there. When are you coming in?
212,757
It’s an arklahoma trail junkies ride. Not a Honda ride, but there will be a few Honda’s there. I know @my99svt is coming also.
May have to ruin the party! HA!
Reactions: sharp and nbomar
my99svt
my99svt
I identify as a lesbian
1,267
5,248
Broken Arrow, Oklahoma
Mine did not have the rubber gaskets installed. It came with new ones though. Did you install these Nick?
nbomar
nbomar
4,416
17,855
Springdale, AR
I didn’t think mine did either. I used a pick and they were down in those grooves. I didn’t put the new ones on. The old ones looked fine and I re-used
Reactions: sharp
sharp
sharp
3,757
14,955
Tennessee
If you did a snorkel that goes straight through the hood with no pre filter you will defiantly need to check the main filter often. I did the snorkel that goes through the hood and trimmed the original pre filter into a circle that fits snug into the aluinum pipe but not too snug just barely snug. Then I drilled 4 holes in the aluinum pipe and ran metal wire about the consiststy of a thick coat hanger wire through it and bent them down. After I bent them down I was able to slide the plastic snorkel head over the wire and screw it into place so it won't be seen. The the factory pre filter that I trimmed will rest on the wire so it will not get sucked down the pipe.
Reactions: nbomar and JTW
nbomar
nbomar
4,416
17,855
Springdale, AR
Mine has the filter head you refer to. Can’t believe how clean my filter was for being 2 years old and 1600 miles.
sharp
sharp
3,757
14,955
Tennessee
I checked my main filter a while back and it was a task to get to it. It was just fine as well. Just like many of y'all I have gotten to know my machine and the weird sounds it makes. If it ever starts to sound different or act different then I will check the filter again, lazy I guess. I will just treat the pioneer like the honda foreman and not worry about it. Lol
