Talon Front Driveline Woes
hondabob
1,316
5,223
Prescott Valley, AZ
The front is more difficult but you can look through the hole in the welded in skid plate and weld it through the drivers side fender panel.
Reactions: 1HasBeen
Lil_Steve
Lil_Steve
544
2,109
Gilbert, AZ
Can this spot welding be accomplished with the driveshaft in the machine?
Yes. Rear is easy after dropping the skid plate, front is a little more work but not bad. Remove this left front panel for better access to the front caps and yoke.
IMG 20210614 191446649 XL
Rear access with skid plate removed
IMG 20210606 114020652 HDR XL
For the front you can either go through a hole in the frame or remove that front panel shown in the first pic for easier access.
IMG 20210606 122643525 XL
IMG 20210606 125108982 X3
Tramguage1
Tramguage1
Texan
7,594
31,395
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
I may put mine up on the rack and do this.
Reactions: Remington
Doogle
Doogle
212
304
Surprise,Az Cincinnati,OH
More info for digestion. A fellow owner asked me to tack weld his driveline and what I discovered solidifies one of the theories about why/how these drivelines fail. This machine is a 2021 R and has less than 2,000 miles on it. Removing the driveline, I didn't feel anything out of the ordinary and everything looked and felt tight. BUT, upon further inspection after wiping off the dirt, I discovered the beginning of what I now believe is an eventual failure.
Honda puts paint marks on just about everything and the driveline is no exception. However, they only paint one cap on each end.
Rear yoke paint mark, everything looks normal...
Front is a different story. The paint marked cup has rotated (maybe others too but hard to tell). Not sure if it is just 1/8 turn or if it has gone around a few times. The cup was still tight in the yoke and the clip had not worn the yoke (YET). The joint and yokes are still good so I tacked welded all 8 cups. Catastrophe averted!!!...
My opinion after all this is that the press fit is too loose and allows the cups to spin. Eventually, this wears the clips into the yokes and causes them to break or come out and the failure occurs.
HONDA, ARE YOU LISTENING!!!
That picture should make every Talon owner want to inspect their yokes. 4 months before I'll see mine again. Great work Paul. I think your post should be added to first line of "What every Talon owner needs to know."
Maybe I don't know how to word Google search well enough. I just spent a couple hours looking for the interference fit for ANY universal joint caps. Couldn't find anything. How can a problem be analyzed without some specs? I also tried to contact Spicer for a spec. Forget contacting them unless you have a website and company name. You're not worth their time I guess.
PaulF
PaulF
1,462
4,817
  2. Talon R4 LV
I am with you on the search. I tried everything and was also unable to find out anything pertaining to U-Joint cup interference fit specs. That is why I decided to test a brand new driveline. This thread is pretty long so you may have missed this post...
Diceman9
7
Does anyone make a replacemant aftermarket driveline that has spicer or moog joints? Should be easy to put one together for a fab shop.....
PaulF
PaulF
1,462
4,817
  2. Talon R4 LV
Nope. The problem isn't the joints, they are high quality sealed joints and last a long time as long as the yokes are tight and don't allow the cups to spin. Problem is with the yokes.
What is needed is all new yokes with tight bores. The driveline yokes are easy to source, it is the slip yokes on both ends that are proprietary and not available until someone in the aftermarket produces them with an appropriate press fit.
Your best bet right now is to spot weld the cups on a stock driveline until someone in the aftermarket designs and manufactures a better replacement.
terratrooper
terratrooper
7
9
Adrian PA
  1. Talon X4
I will be checking my 2020 X4LV soon. I cant imagine Honda sources different yokes for 2 and 4 seaters but I haven't seen anyone complain about the X4 yet. Am i going to be the first?
Allegedly the problem is only on the two seater….🤔
See post 28…..
PaulF
PaulF
1,462
4,817
  2. Talon R4 LV
The 4 seater has 2 shorter drivelines, 3 joints and a center carrier bearing. The only shared part appears to be the front yoke. Everything else is different, even the connection at the sub-trans.
Maybe a different vendor supplying the 4 seater driveline with better quality, who knows? Only way to tell is order a new one and inspect/test it but that would entail over $400 in parts.
Doogle
Doogle
212
304
Paul I know you have done a tremendous amount of work testing. I am back to my Talon finally and ready to inspect it. While thinking about welding the caps I wondered about another dimension on the yokes. How much end play is there on the journal cross? If there is too much end play, could that cause hammering on the clips also? I wouldn't think it could be a problem, but if they can't get the bore fit right. If I remove my snap rings and tack weld the caps, could they possibly need to be positioned different than where the snap rings would place them?
PaulF
PaulF
1,462
4,817
  2. Talon R4 LV
The new driveline I tested has zero end play. They yoke spread and outside clip distance were the same (this is normal).
The problem with the stock yokes is they are too lose and the caps begin to spin and the clips wear into the yoke and eventually break or come out causing the cups to come out.
Tack welding the caps is not intended to hold them in, it is intended to keep the caps from spinning in the first place. If you can keep the cups from spinning, you will keep the clips from wearing the yokes and flying out and avoid the failure altogether.
Doogle
Doogle
212
304
I can't tell from the pictures I've seen, if the clips are still in with the spot welds. I assume they are, but can't tell.
Doogle
Doogle
212
304
I will take my drive shaft out to weld it because I'm not a confident welder, I'm retired and have time, and I can better inspect their condition. But while I was installing a front camera yesterday, I looked down at the drive shaft and wondered why a better welder couldn't stretch down in there and spot weld the caps. I've read many people have trouble removing from the bottom. I'm sure others have considered this, but I didn't read it where I was looking. Just a thought to consider.
SLOWPOKE693
SLOWPOKE693
2,010
7,790
Somewhere in Texas
Are you sure you want to take the driveshaft out to weld it? You pretty much have to pull the diff out to get the driveshaft out, and if your digging onto it that far I'd buy an RB3 billet rack and swap that in at the same time to avoid having to pull the diff out again if/when the stock rack breaks.
5,739
26,297
Yes, you can weld the caps with the driveshaft in place, @Lil_Steve posted pics in post #82.
Doogle
Doogle
212
304
Boundertom removed it in post #57. I'll attempt that first.
