Todd's 2019 Talon X trail build
toddvdh
toddvdh
1,121
7,412
Green Bay, WI
Reactions: sspeederr
sspeederr
sspeederr
391
661
Those look great. Do you have a link to the build? I’m assuming usual MDF ring on stilts, then covered and fiberglassed?
No I kinda just winged it with ply wood and fiberglass nothing to it really just to do it made both in 30 min
toddvdh
toddvdh
1,121
7,412
Green Bay, WI
So, I'm back from vacation and ready to work of stuff. I have the roof where I'm happy and started painting it this afternoon.
This morning I started the install on the bump seat. It came nicely packaged and installed in about 1 hour at most.
123
5E553C0B 6C3C 498D AFEB AA2D7AD60E1D
toddvdh
toddvdh
1,121
7,412
Green Bay, WI
I didn’t have it pushed back far enough yesterday when I tried to install it. The bracket was correct. I didn’t realize when they said “pry” it better the seats, that I would have to climb in the machine and feel like I was going to break the seats getting it in between. But, I got it. ;)
8E6126B3 3655 41B8 A0D6 5C803D88CDAE
F481C7B1 E285 4F96 AA42 9F8B173CDA78
The machine goes in low now.
7C62AFE5 372A 4A93 8BE1 DFB111489678
toddvdh
toddvdh
1,121
7,412
Green Bay, WI
Top view.
EEAFF491 0421 4EE1 9472 C84FF5563D50
Here is my 50lb 6 year old sitting in it before I pushed it between the seats. Should be good for at least 2 years with the lower cage on the machine.
5D1F709F A6BB 4C8F 867D B2161FB5883B
sspeederr
sspeederr
391
661
Top view of how far it sticks over the seats.
i have the same seat and mine fits between the factory seats and i am able the get in low gear no problem
it looks like your bracket maybe on backwards try flipping the bump seat bracket and put it between both seats i have about 2 in clearance above the cup holders your looks like its sitting on them.
toddvdh
toddvdh
1,121
7,412
Green Bay, WI
I was poking around today looking for ways to spend more money on this machine, and found out it already has mud gaurds in front of the rear tires already. I just need to grab a few pushpins, or zip ties.
136
Reactions: lowranger
toddvdh
toddvdh
1,121
7,412
Green Bay, WI
I got my roof on today. It's 1/8' aluminum. Hopefully the black paint holds up. I used some spacer clamps on the middle bar to give it a little arch. I also used some 1/2" gasket by the bolts to try to stop rattling.
131
132
133
toddvdh
toddvdh
1,121
7,412
Green Bay, WI
It didn’t fit quite right when I got home. Over bent the angles. It’s about 1-3/4” too narrow. 🤔
I think I’ll cut some slits in the bends to open them back up a little and just weld it tomorrow. Your not a good welder until you’re a good grinder!
Im trying to decide if I want to do a swing away hinge, or make it drop in with pins. I don’t really think I’ll be opening it that much. I’ll use the 1000-5 if I need a bed.
Overall it actually fits really close for my crappy cardboard template and 45 minutes worth of work so far!
toddvdh
toddvdh
1,121
7,412
Green Bay, WI
I’m not sure if I’ll do a spare tire mount or not. It does fit inside the bed right now. I haven’t needed a spare tire on any of my trail rides for the last 20 years. I just carry a plug kit and I’ve only used it once on someone else’s machine. But, I’ve heard the talon needs some rear weight.
Reactions: CID and Mudwing
toddvdh
toddvdh
1,121
7,412
Green Bay, WI
Well, I decided to go with a drop in type design. I put 4 clamps on my cage and put 4 pins on the gate. I’ll secure it down with a couple bungee cords because I don’t think I’ll be taking it off and on very often. It stays where it is without the bungees and doesn’t rattle, but I figure they are cheap insurance. I’ll get a pic on the machine this weekend.
931FC985 B9D2 477A 9430 7FF668336D13
