Todd's 2019 Talon X trail build
toddvdh
toddvdh
1,121
7,412
Green Bay, WI
Here it is on. I decided to leave work early!!
97B470D8 6E33 4BF7 B8D3 293203CB3EEC
4A9866F4 38AF 419A 8C2F 0A19B9C2B812
toddvdh
toddvdh
1,121
7,412
Green Bay, WI
I got my light bar mounted this morning. It’s a 14” one from harbor freight. I had taken it off my ranger before I sold it. It should be more or less protected by the front bumper.
Now the fun part of wiring it in comes.
E8CA162E 973F 4275 A702 BC9D82CB7060
A5304513 12CD 4670 AD1B 52D896E52841
toddvdh
toddvdh
1,121
7,412
Green Bay, WI
Got it wired in. While I was doing it I changed the winch trigger to be key on so my kids don’t run the winch while the key is off in the garage. :confused:
The previous owner had a few holes in the dash with rubber plugs, so I took a dremel and made one work for a switch I bought.
0A490F1F 413E 4EC7 A5AB 9AE21A414138
There was a hole drilled in the compartment under the gauge, not really sure why such a big hole, but I glued the rubber plug from the switch hole in.
F0FDBBB0 8124 40F7 AD90 3FCCD4564FB1
toddvdh
toddvdh
1,121
7,412
Green Bay, WI
And the past few days I took apart my kids old lt-80 and repainted it. It was pretty rough (plastic cracked) when I bought it, so I zip tie stitched it up. This is the 2nd time I’ve painted it. But it runs good and I only paid $200 for it 3 years ago.
54B0B1CE A614 49FB A167 C218F8518C0E
toddvdh
toddvdh
1,121
7,412
Green Bay, WI
I bought a box today for the rear. It was only $29. I’ll probably just add a couple eye bolts and strap it down. I don’t always need a box but sometimes it will be handy.
4D99EA7E DB80 4B0D A00A C37E2529690D
30FEE252 E854 4C72 9F98 5A9066E42EC4
toddvdh
toddvdh
1,121
7,412
Green Bay, WI
Here is how my rear shocks came. Tenders compressed, and cranked way down to 5-3/4” from the top of the shock.
I have about 14-1/2” of clearance in the rear, and 13-1/2” in the front. Measured from the ground to the skid plate on the center of axle. I’ll be trying to get the front up a little more
BDE0ABEE 845D 445F 9C4B EDA51FE7FFF2
I put the rear bandit tender springs on today. I used TerryH (from YouTube and this site) suggestions. I set the rear at 4” of “preload”. The measurements to the rear skid plate was 14-5/8”. So the bandit tenders do raise the rear end, and the machine actually moves now when I jump on the rear bumper. :)
AA3B52C5 0793 4607 BD25 C4A4E761230C
Here are the bandit tenders vs the stock tenders.
96BF5A68 24A0 49A4 ACF3 30DFC45DA1DE
toddvdh
toddvdh
1,121
7,412
Green Bay, WI
My front shocks only have 3-1/2” of “preload”, so if I go to the 5” on TerryH suggestion, it should raise the front where I want it to be.
Reactions: BrianN
5,750
26,408
There are already 4 D-rings in the bed, I used them to tie down a similar TSC box. Remember Terry changed all his springs IIRC so his preload probably won't be your preload.
Reactions: toddvdh
906UP
906UP
15,035
142,848
da Yoop
Don't worry about preload, adjust by "ride height", I played around with mine until I got it where I like it. I think I settled on 13.75" front & 13" rear measured from the skid plate to the floor. A little more height in the front is good for handling
Reactions: toddvdh
toddvdh
toddvdh
1,121
7,412
Green Bay, WI
He did a just tenders video then he did a full spring package later. The numbers at least give me a starting point since bandit doesn’t give any info.
Reactions: CID
toddvdh
toddvdh
1,121
7,412
Green Bay, WI
I got one of the fronts changed today. The bandit tender spring is about 1" shorter than the stock tender, but is way stiffer.
I snugged the nut down where the springs aren't rattling. Then I added about 1-1/2" of real preload. I'll change the other one and put them back on and set ride height in the front. I've read 1/2"-1" higher in front for good handling. Thanks.
toddvdh
toddvdh
1,121
7,412
Green Bay, WI
I ended up setting my preloads at 5” front and 4” rear. It gives me 15” of clearance in the front, and 14” in the rear. I’ll fine tune these after I go for a ride this weekend.
This weekend will be the first time I actually drive it more than around my yard and neighborhood. The trails by my cabin aren’t open until may 1st, but I can hit some fire roads and trails through county forest.
I spent $30 and bought some polycarbonate to rig up a short windshield to see if I like it. Attached with zip ties for this weekend. :cool:
27630EA6 E409 4235 AF48 8B03256CA662
5E50CCC3 3527 49EA 89AF 765447D13689
toddvdh
toddvdh
1,121
7,412
Green Bay, WI
I added some u-bolts to the box by the 4 d-rings in the bed. I decided just to zip-tie them for now. It’s actually rock solid and this may be how I keep it. 🤪
1D21837A 079F 4108 BA9A C4D59F3AA7A1
72AE10B3 BEE7 49BA 9DED ADE2F2EB6494
5E07CC56 B6BD 459C 8F9D 96C266AFE1A1
toddvdh
toddvdh
1,121
7,412
Green Bay, WI
My shock covers also came in. They are pretty nice for $61.50 on eBay with free shipping. They are a waterproof material with Velcro down the whole backside.
0FC8940F 35A9 48F9 83DB 1BA66CC31FEC
E5FACE04 FD31 4D75 96CC E5C86FBBE574
The rear ones fit right over the plastic protectors, so l left them on. It’s pretty snug so I am going to have to keep an eye on them so the plastic doesn’t rip them. I may end up taking the plastic protectors off.
0C6348C0 C71D 4BEF 9FB3 B871C34044E9
Reactions: TripleB
5,750
26,408
I'd double or triple those zip ties, they're going to get 'worked' in this application. Or get the 1/2" zip ties, even better.
I never thought about putting my shock covers over the plastic shields, I squeezed them in between the shield and spring. I have Shock Therapy's front limit straps on the way - they use a nylon strap around a coil midway down to control flapping so I'll have to slit the covers unless that strap is long enough to go all the way around the spring.
Reactions: toddvdh
toddvdh
toddvdh
1,121
7,412
Green Bay, WI
I put them on mainly for looks. I'll take them off and wash underneath every few rides. Maybe they give a little protection against mud, but mainly looks. :)
