P1000 What are my options - slightly bent tie-rod
txsurfer
txsurfer
496
990
Santa Fe , TX
After cleaning the Beast up from the weekend I discovered a bent tie rod. I'm not suprrised as my wife and I were riding it pretty hard around some square edge rocks/ledges. Not bent too bad so I am wondering if I could (a) easy route - run bad joint out enough to comp (b) straighten in press (c) replace
File May 03 9 05 17 AM
sporttrac4x4
sporttrac4x4
1,177
2,082
ILL.
Order a new set but keep going on the rocks intel it's bent to bad you cant ride it no more. That,s what happens when you ride on rocks that are to big and I notice you don't have A arm guards need to get some if your going to rock ride. "good luck".
Reactions: pct and sharp
Jshell3
If it breaks it might take out an axle, brake line and/or ball joints.
Having met SnuffnWhisky, I'd pretty much take his opinion in the highest regard.
txsurfer
txsurfer
496
990
Santa Fe , TX
would this tool ( inner tie rod removal ) be worth the $40 at harbor freight? Ness?
Image 21440
Reactions: sharp
snuffnwhisky
snuffnwhisky
Village Idiot
3,303
18,152
Cullman, AL
  2. Other Brand
It unscrews from the rack. On the spindle end, get someone to pry up on the tie rod and smack the knuckle with a hammer on both sides at the same time - 2 hammers. 1 might get it. Hit the knuckle on each side where the tie rod bolts down. A tie rod removal fork almost always ruins the boot.
W
Westtnpioneer
Edjumacated
350
603
West Tennessee
I keep a spare one. It was like 20 dollars and if you try and bend that one back it's going to make it that much easier to break.
Gator
Gator
The Most Unknown Member
2,475
10,396
Louisiana
Go by Autozone or one of the other parts houses. Borrow/rent the tool.
Buy a new arm, or two. Keep the old one or a new one for a spare. (I realize that I don't have a spare. Shame on me.)
Also, replace the boot. It's just easier.
Reactions: sharp
txsurfer
txsurfer
496
990
Santa Fe , TX
I have a banding tool I bought for CV boots - I assume i could use this on the rack boot? OR does some one have a part number for a airbox type clamp that will work?
pct
pct
Lost in the hills
790
1,023
Letart WV
Replace it and keep the old one for a spare that happens often with the guys I ride with lucky I have not done one yet on the 1000
Reactions: Chadp2003 and sharp
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,567
Greenville, Mo
I just reused the stock band. Used side cutters to re crimp.
208,013
Just turn it 180 and it will be perfect next hard hit, HA! Talk about a red neck fix
Reactions: sharp and nbomar
265,563
Reactions: Windrock1000
