P1000 clutch slipping again
Deanb
Stonyplain
Does anyone know of any clutch updates on the p1000 just slipped my clutch in reverse will take it back to the dealer. Glad I bought the extended warranty just so disappointing can't take the machine off the pavement
Reactions: Hotwlz and sharp
Was yours the one with 32's and portals or IGR?
266,947
He has 8 posts in 14 months, 7 of the 8 posts are about clutch failing twice. Didnt see any other info about his setup. Typical, things going ok no posts, anything goes wrong get online and complain about it.
hondabob
1,163
4,538
Prescott Valley, AZ
The reverse gear is high. I use it very little and backing up a short distance won't heat up or damage the clutch. I keep it above 3 mph if I'm backing up very far. Going forward in low range I keep it above 3 mph. Just below 2,000 rpm at about 1800 rpm the clutch is slipping. Big tires just make it a lot worse and most of us know how to avoid clutch damage. For super low speed use I drive my Pioneer 700. All the belt drive UTV's without a wet clutch can run along at 1/2 mph without belt damage as long as you keep moving. I use my Pioneer 700 for tough rock crawling now and I really liked my 2012 RZR 570 due to the light weight. Hopes this info helps avoid future clutch problems. I just hate to see my UTV's go into the shop and its usually 2 to 3 weeks to get it back.
64,272
No updates yet. But rumor mill is always turning. Latest is a look at the 2018 line. But parts fish have yet to be released. Soon we hope!
Thanks @hondabob for the info.
320,711
Again instructions on how to drive the Pioneer to not have clutch issues. It's a utility rig made to tow a ton not a sport it should be able to take that. I've always had a Honda and never had to tell my family what not to do I hope this problem gets remedied for everyone.
Can't disagree with that... I was amazed how close to failure mine was... and it was strong up until it went.
Deanb
Stonyplain
Well I have my pioneer back. With a new 1/3/5 clutch works great again still no update from honda. I now know I will go through at least 1 clutch per year .i might dump it if Honda does not come up with a fix soon . Some folks are on there 4th clutch has anyone heard anything yet ?
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Lmfao!!! Priceless:rolleyes:
Reactions: JTW
richmx22
Ok I was winching a tree that was falling toward my shop yesterday and while pulling slowly in reverse/ winching I had no problem saving my shop from damage. Unfortunately today went to use the pioneer 1000 to haul the logs away and clutch slipping and doing weird things. Now reading this thread it looks like my pioneer is very light duty? I bought this Honda to avoid all the belt drive machines. Now a $150 belt replacement is looking good compared to my Honda issue. Any idea on where to get this service done and how much?is Honda my only chioice or does any aftermarket shop have an upgrade?
Reactions: 0860silverado
Yeah that was a terrible idea!! Honda is warranting the clutches and also now doing a clutch cover upgrade as their fix, which delivers twice the oil to the clutches preventing burn out. Contact your dealer and have it taken care of. It’s free warranty work. I understand your frustration but did you read the manual or do any preemptive research before you purchased your machine? It’s a well known issue that reverse and first are a little high for a machine without a torque converter. If you’re barely turning any RPMs then you’re potentially burning clutches! And remember... It’s not a f***ing tractor!!
Deanb
Stonyplain
Hopefully hondas recall will help otherwise I am thinking about the defender xmr
0
0860silverado
947
1,817
louisiana
I'm gonna patiently wait for reviews and potential common issues to surface and be corrected with Polaris' new Ranger 1000. Completely redesigned from the ground up including the drive system. I got smoked on my Honda because I bought the first year release. Never again!!! Good luck on whatever you decide!
DRAGFOOT
DRAGFOOT
213
350
MINNESOTA
By "new drive system" are they referring to the prop shafts that now have CV joints instead of U-joints? Or is there more to it? I was just on a fishing trip with my buddy who is a tech for a Polaris dealer and he says the new one is still a joke.
