P1000 Fox shocks and camber
hadleycat
45
66
Metamora MI
I installed the fox shocks on my 1000-5 deluxe. I assumed the preload was set from the factory but I have a 1/4” negative camber in the rear. Is this how the machine is supposed to ride. I know the factory deluxe shocks with load leveling were also 1/4” negative camber at rest. I have also confirmed that I have the 1000-5 shocks and not the 1000-3. Thanks
Pilotadam
Pilotadam
326
735
Pell City, Alabama
You need to measure your ground clearance and set your preload for your P1k5. Depending on your accessories and riding gear it could change the required preload. I know I lost 1.5in of ground clearance due to accessories and gear. That is the nice thing about adjustable preload. I ordered my Fox shocks back in Nov and still waiting for the fronts. I got the back installed and put new springs on and got my ground clearance back.
Sent from my SM-G781V using Tapatalk
107,350
Cuz u need new control arms to fix it. Your stock arms are not adjustable. If you put preload on those shocks that's going to change a lot of stuff including camber. That's why you need the adjustable arms if you want your camper to be a certain way either that or you just deal with it. That's actually not a great option though. And no the fox shocks generally do not come preset they're just at a general starting point for preload from the factory
hadleycat
45
66
Metamora MI
Thanks guys, I am pretty happy with it as is for now but once I get my spare tire carrier on the back I am going to add a bit of preload. I came up with an idea that might make this a simple job. I am going to add a bunch of zip ties to the coil springs with the machine at rest. Then jack the machine up just enough to take the tension off the shock adjusting rings. Spin the rings by hand to add the preload then remove jack. Cut the zip ties with the tension removed from them. Not sure if this will work or not but am going to try it.
JMynes
JMynes
541
3,226
Augusta, Maine
If those zip ties don’t hold any body parts in the vicinity will suddenly be not yours anymore.
  • Haha
hadleycat
45
66
Metamora MI
Finally got around to adjusting the preload on the springs. Put 5 turns on the front shocks and 8 turns on the rear. This got me to 0 camber. The zip tie trick worked like a charm. Not dangerous at all. Took me 1 hour to set the preload on all 4 corners. Lifted the machine 1 1/4” by setting the preload properly. I used 12 zip ties on the front and 16 on the rears
BAD0A1A4 DBE1 4A49 9896 22A7DE044AA5
107,350
I give you 10 min on trail and those are gone! 🤣
27B44B39 DEE9 45F0 9D39 A57335A2C1AF
hadleycat
45
66
Metamora MI
Hey Rem did you ever figure it out that you have your rear shocks mounted on the wrong sides. Reservoir goes towards the front of the vehicle
What is the point exactly with the zip ties? It was just to help with preload right, he's not leaving them oN
107,350
Yep. The pic you seen was white a few years ago And they were installed that day and flipped back the right way that day. Alcohol was involved lol
107,350
What is the point exactly with the zip ties? It was just to help with preload right, he's not leaving them on?
Right. And no he’s not leaving them in. I was also just making a comment about those stickers that he put on the inside wheel wall where the mud and water is going to rip right into them and they’re going to rip right off lol. I’ve always used ratchet straps but actually had the shocks off the vehicle and on the bench. Makes it a lot easier. That’s a lot of large zip ties that are about three dollars apiece
Reactions: toddvdh and trigger
hadleycat
45
66
Metamora MI
I'm not following why you added the zipties. Just take weight off the tires and turn the preload down
Is that how you have adjusted yours?
hadleycat
45
66
Metamora MI
Right. And no he’s not living them in. I was also just making a comment about those stickers that he put on the inside wheel wall where the mud and water is going to rip right into them and they’re going to rip right off lol. I’ve always used ratchet straps but actually had the shocks off the vehicle and on the bench. Makes it a lot easier. That’s a lot of large zip ties that are about three dollars
hadleycat
45
66
Metamora MI
Right. And no he’s not living them in. I was also just making a comment about those stickers that he put on the inside wheel wall where the mud and water is going to rip right into them and they’re going to rip right off lol. I’ve always used ratchet straps but actually had the shocks off the vehicle and on the bench. Makes it a lot easier. That’s a lot of large zip ties that are about three dollars apiece
Im more of a rock crawler guy. Not a big fan of mud puddles
207,989
When I got my shocks I set spring sag with pre load the adjusted camber on my SATV A-arms?
