P1000 Jackal's P1000-5
Well just as well get this started off. For those of you that followed along on my Pioneer 500 build, I pretty much bought all my accessories before I even had the machine in hand and within 3 weeks of having it home it was all tricked out like I wanted.
Thanks to @HondaProKevin from Honda of Chattanooga I will pick up a Red Pioneer 1000-5 Deluxe on 12/22 just before Christmas. :)
Stay tuned going to be a long and expensive 2 months. :D
7,145
27,193
I know I don't have a P1K, but here is a quick shot of the belts nearly finished. Only need to anchor the inside shoulder belts. Not sure on where I am going to anchor.
P.S. not sure what these buckles are made of but I burned up a couple drill bits, they are really hard!
Sent from my SAMSUNG-SM-N930A using Tapatalk
7,145
27,193
266,530
Why not anchor both top straps together like on my P500 build? Just used strap metal around the tube at top rear of seat.
Reactions: Tramguage1
7,145
27,193
It looks like he used plumbers strap. I think I want to find a more significant mounting point. I was able to use 3 of the original anchor points and bolts.
7,145
27,193
@JACKAL sorry to hijack you thread!
266,530
Flat bar or plumbing strap?
It is heavier than plumbing strap but similar in appearance, I get it from Farm supply stores like TSC or Rural King. It is 1.75" wide x 1/8" thick and is pre punched with 3/8" diameter holes every 1.5" they are sold in 4 foot sections for about $6 one piece can be cut to secure 4 harnesses.
7,145
27,193
Thanks, I'll be ready for the Silver trail riders next year!!!
Reactions: BIGRACK
266,530
It is heavier than plumbing strap but similar in appearance, I get it from Farm supply stores like TSC or Rural King. It is 1.75" wide x 1/8" thick and is pretty punched with 3/8" diameter holes every 1.5" they are sold in 4 foot sections for about $6 one piece can be cut to secure 4 harnesses.
Detailed pictures of this material and fabrication in the post linked below.
P500 - Jackal's P500
X4Dice
X4Dice
87
130
USA
Now that I am going on longer rides frequently got tired of the OEM setbelts rubbing on my neck / collar bone area and wanted something more comfortable.
Since I am completely happy with the BEARD 4 point restraints with automotive latch that I have in my P500, I added a pair to the front of my P1K5D. Keeping the center seat belt for car or booster seats for now.
Installation was very easy, on drivers side behind padded headrest is a hole already between the two mounting bolts. There I used a single 3/8" x 1.25" bolt to secure the upper harness mounts together to backside of headrest mount. On both sides used the OEM location and bolts for the bottom harness mounts. The passengers side top is a little different but simple drilled a 3/8" hole in the same place as on drivers side and used a 2.5" long 3/8" bolt due to the size and shape of the OEM metal headrest bracket.
These padded harnesses are VERY comfortable as well as keeping you put on rough terrain making the ride even more enjoyable. In case of rolling the machine these will keep you in place even if you end up on your roof.
Beard 4-Point Safety Harness with Automotive Buckle | UTV | Rocky Mountain ATV/MC
How do you like your harness after a few months of owning them?
Reactions: Manwell and Delton
Manwell
Manwell
803
2,439
Not trying to reply for @JACKAL, but I installed the same belts in the same way he did and I love them! The only downside is they take probably twice as long (maybe more than that) to get buckled in compared to the stock over the shoulder belt. I really feel secure strapped in with those things! I'd do it again...
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
Buckling up I'm not worried about. How fast can you unbuckle is what I want to know. As in rolled over in water (or on fire) and need to make a hasty exit. That's what's important to me. I heard it's a quick process but checking to make sure.
Manwell
Manwell
803
2,439
Unbuckling is not a problem whatsoever... It takes longer to buckle up because there are two shoulder straps to get in place (and tighten) added to the waist buckle. I love mine... If we get together again before you make the modification you can feel free to check them out very closely and drive with them.
266,530
No more difficult than any other car type buckle. Been on my roof once kept us perfectly in place until we were ready to get out and upright the machine.
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
Thank you. Exactly what I wanted to hear.
Reactions: Windrock1000
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
Hopefully we can get together on Mary's Ridge soon.
Byrdman
151
215
Kentucky
Haven't posted any updates in a while currently addressing in cab heat. Insulation installed the right way under the plastic and double layer between seat belts next to head and header pipes along with 4" bilge fan. Removal of seat back and plastic cover between seat bottom and back. Insulation BEFORE it heats up the plastic next to the occupants.
Will post as insulation is installed. Why is it so hot normally because only 2" gap and 1/8" of plastic separate engine from occupants. View attachment 19185
Any added benefit to installing two of these fans? I've ordered two but I see you and many others have just installed one.
Reactions: Delton
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
@joeymt33 and I did a test with a temp gun. He has one 4" and I have two 3" blowers. Covering exact same ground, his seat measured lower temps than mine. So I'm saying a 4" would be more efficient.
Byrdman
151
215
Kentucky
Awesome, thanks!
