P500 Poll- P500 trouble costs (not maintenance/accident)
P500 Trouble Repair Cost total, (not maintenance )
  • $0
    Votes: 99 83.9%
  • <$50
    Votes: 1 0.8%
  • <$100
    Votes: 6 5.1%
  • <$250
    Votes: 7 5.9%
  • <$400
    Votes: 3 2.5%
  • <$700
    Votes: 1 0.8%
  • <$1000
    Votes: 0 0.0%
  • More than $1000
    Votes: 1 0.8%
  • Total voters
    118
Mudder
Mudder
NTC Ambassador of Walls
11,301
83,894
Thought this Poll might be helpful for Manufacturing dependability or defects questions. Don’t include routine maintenance or accident/abuse repair cost. If you had a significant cost, the model year would be good to know, as well a type of issue, (engine, transmission, electrical, etc). 2017, no problems.
12/3/17... There are 895 forum members listed with P500s. (Thanks @Hondasxs)
Reactions: rocmar
William
William
1,442
2,887
Flowood MS
Seal on rear end. Passenger side axle seal. Simple repair. Leaked water in since day 1. 2015. If my rear end gets any slack in bearing, or gets louder my selection will change to <$700 for a new rear end.
Reactions: rocmar and Mudder
rocmar
rocmar
4,741
5,773
4 CORNERS
There's no where near..that number of
895...ever on this forum..
just saying...
your active members. ..are
minumal. .
Reactions: trigger
rocmar
rocmar
4,741
5,773
4 CORNERS
From wat I've read..
the 2015 model (original ).. seems
to have the fewest...problems...
overall...
IMO
Mudder
Mudder
11,301
83,894
Yep, may not be active, but registered, . To buy new, or used... hopeful for a good number of votes per views.
Reactions: rocmar
rocmar
rocmar
4,741
5,773
4 CORNERS
Be interested to see...how
many p5...owners chime in...
Reactions: Mudder
rocmar
rocmar
4,741
5,773
4 CORNERS
Wanna see..wat yr..
has the most problems...
I do know...water & mud
...are not..,Any SXS friend....
sam3006
sam3006
144
411
Damascus, AR
Mine is a 2015 model, bought in the summer of 2014, that I've got about 2000 miles on. I've spent way more on it than I want my wife to know about, but it's all been on accessories and things I've added on to it, nothing on it because of breakdown or defect. The only thing that's ever given me any trouble is the winch and that turned out to be a grounding problem.
KYhillbilly
KYhillbilly
547
1,645
Ashland, KY
Mine is a 16 I bought used in Mar 17, wasn't fast enough for previous owner. I don't ride a lot only around 350 miles on it but its all hills, red clay mud and sandy creek crossings. Except for cleaning sand and mud out of the front disks no issues at all.
hondasrule
hondasrule
50
195
ontario
Mine is 2017 only issue I had was front brake pads were gone at 798km. (496miles for my American friends) I ride in wet mud holes though. I replaced them with the MUV700 big red stock pads. Have just over 1200km on it now. (746mi)
iowaguy
iowaguy
624
1,424
Eastern Iowa
WIN 20171204 205147 3555 miles,$00.00 repairs
HondaTech
I havent done the first repair to any P500 other than the formentioned seal leaks here and there and an axle boot cracked near the band. I have had 2 random starters that had the magnets come apart from the cases. This use to be a common Rancher problem, but it seems Honda has fixed that model. We also saw one where the 2 bolts holding the parking brakes mount on just fell out. Not sure how, guess they were just loose from factory.
This isn't surprising, they are really just a 2 seat Foreman, which is just a overbored Rancher and there rock solid.
I havent put a wheel bearing in any Pioneer (or Big Red for that matter), no ball joints either or a-arm bushings. Couple bent tie-rods (P1K) and few axles that have come part inside the boots.
