Leukic
[email protected] I would love this template
Not sure why? Same address I got the notification from the forum of a reply haha.I tried that address and it bounced back.
Question for CTD or those who have done this... Does the sides come exactly to the edge of the side rails? Wondering how much to bring out to protect rails.
Sent from my Pixel 3 XL using Tapatalk
What do you mean exactly? Like bolting a piece of angle on the skid and frame? Trying to avoid kickers/slidersI would still recommend a tube slider gusset on the rock rails.
Awesome thank you sir. Only thing is I'm not a fan of drilling in my frame. Wondering if I could maybe notch the skid right there and use a squared u bolt, by welding it to the gusset and using a plate over top of the frame?Here is the rock slider post from my build thread. 3/16" formed Ruffstuff tube gusset. VHB bonds it to the tube and it's bolted through the skid plate. Rock solid and no crevise for corrosion
P1000 - Todd's 2018 Build
You can see them here in red above my skid plate
I see yours bends up behind the front tires.. some others in this thread do not. I like the idea of having it curve up, but will I need forward arms with 28" tires or they rub? I thought someone said that in another thread..
I have stock arms and 28s. I made my outer panels but they don't rub the tires
Fox shocks but no liftand no lift?
Todd, as far as the width on your skid, is that the width of the template? Or did you add a little to each side?Here is the rock slider post from my build thread. 3/16" formed Ruffstuff tube gusset. VHB bonds it to the tube and it's bolted through the skid plate. Rock solid and no crevise for corrosion
