P1000 DIY Skid Plate Template
Claym325
6
12
Question for CTD or those who have done this... Does the sides come exactly to the edge of the side rails? Wondering how much to bring out to protect rails.
Sent from my Pixel 3 XL using Tapatalk
Reactions: Biteme
ToddACimer
ToddACimer
Pioneer 1005-2
3,555
14,593
Oshkosh, Wi
I would still recommend a tube slider gusset on the rock rails.
Reactions: Biteme
Claym325
6
12
What do you mean exactly? Like bolting a piece of angle on the skid and frame? Trying to avoid kickers/sliders
Reactions: Biteme
ToddACimer
ToddACimer
Pioneer 1005-2
3,555
14,593
Oshkosh, Wi
Here is the rock slider post from my build thread. 3/16" formed Ruffstuff tube gusset. VHB bonds it to the tube and it's bolted through the skid plate. Rock solid and no crevise for corrosion
P1000 - Todd's 2018 Build
You can see them here in red above my skid plate
IMG 20190531 173145
Reactions: Biteme
Claym325
6
12
Awesome thank you sir. Only thing is I'm not a fan of drilling in my frame. Wondering if I could maybe notch the skid right there and use a squared u bolt, by welding it to the gusset and using a plate over top of the frame?
Reactions: Biteme
ToddACimer
ToddACimer
Pioneer 1005-2
3,555
14,593
Oshkosh, Wi
I wouldn't worry about drilling a few holes. I think I drilled over 100 holes in mine before I rode it. I'd rather add the strength now before bending the sliders and being unable to fix them without lots of welding or full side frame replacement. My sliders can support the weight of either side with both tires off the ground and 4 guys in the machine. Stock they flex when you step on them.
15% off Ruffstuff today using code DanDay at check out.
Universal Tube Reinforcement (Single)
mjn
mjn
1,409
5,206
SE Washington State/N Idaho
I see yours bends up behind the front tires.. some others in this thread do not. I like the idea of having it curve up, but will I need forward arms with 28" tires or they rub? I thought someone said that in another thread..
Reactions: Biteme and DanDan
ToddACimer
ToddACimer
Pioneer 1005-2
3,555
14,593
Oshkosh, Wi
I have stock arms and 28s. I made my outer panels but they don't rub the tires
Claym325
6
12
Todd, as far as the width on your skid, is that the width of the template? Or did you add a little to each side?
Reactions: DanDan
ToddACimer
ToddACimer
Pioneer 1005-2
3,555
14,593
Oshkosh, Wi
I've never seen the template. My edges are 16" from the outside of the frame
Muttly
Muttly
34
80
Mid MI
Check my pictures in post # 70, I cut the sides 16-5/8 wide for a little protection
Reactions: Claym325 and DanDan
