P1000 Jackal's P1000-5
jstreun
10
sallisaw
I ended up getting about 1/2 my switches today, enough to play with in setting up the jumper lines for the whole set. What I have pictured below is incomplete (using two 4 switch banks instead of two 6 switch banks*) but serves the purpose for now in demonstrating on setting up the various switches. *Note to self when ordering from Amazon make sure it coming from USA not China or you wait 6 weeks, live n learn ;)
Switch Schematic for SVT switches:
So for the wiring pictured below here is the layout:
RED - Hot wire coming from Honda Black/White ignition keyed accessory wire to the switches power in terminal.
WHITE - Hot wire coming from Honda Brown light switch wire to switched backlit LED's - Switches light up when headlights on.
GREEN - Ground wire from switches to ground.
BLACK - jumper wire from Winch Power ON/OFF to Winch Momentary IN/OUT rocker - A secondary measure of killing power to winch solenoid.
Initial testing, everything lights up perfect:
View attachment 8471 View attachment 8472 View attachment 8473
Well that's it for today, tomorrow will be installing the dual battery wiring kit with isolator, cutting out a temp switch plate from OEM skid plate material, mounting the switches in the switch plate & dash, installing (4)- 18 watt pod lights for front & rear added lighting, and maybe even getting around to getting the GPS installed.
jACKAL THANKS YES I HAVE WIRED MY PLATE THE SAME AS ABOVE. ONE QUESTON I HAVE IS ON THE 7 PIN SWITCH YOU HAVE IN INK PEN DRAWN ON SWITCH CARD INDICATING YOU WERE POSSIBLY JUMPING #3 AND # 6 AND #1 AND #4? IS THAT CORRECT? LAST QUESTION I DONT UNDERSTAND THE CARD WHEN IT STATES CONNECT #2 (+) FROM YOUR SOURCE AND #5 SAYS SAME THING DO I JUMP THOSE OR WHY IS THERE TWO. ALSO CONNECT #6 TO YOUR RELAY OR ACC.( PUSH DOWN SECOND APPLICATIONS) #3, 4, 6 ALL STATE THIS AND #1 HAS SAME EXCEPT ( PUSH UP APPLICATION). COULD YOU ELABORATE ON THIS LANGUAGE AS THERE ARE NOT PICS THAT I HAVE SEEN ON YOUR BUILD OF WIRING ONCE THE PDM IS ATTACHED. THANKS AGAIN FOR ALL YOUR HELP.
273,521
OK back to basic if you can't understand the pin out card that should have came with your switches,
There is 8 possible spades for the back of the rockers they are universally numbered as such:
8 7
1 4
2 5
3 6
as in top of picture here: 17083 7aa9fde911bcbb2f5862470b4f53aa8a
EACH SPADE DOES A DIFFERENT THING DEPENDING ON WHO MAKES IT!!! OTTRW is not the same as STV
This is ONLY for STV Switches here: 17084 7beeade91b05af18df6efc9c2c2f6e90
For a 7 Pin Rocker Switch from STV that is a momentary on UP and momentary on DOWN to run a winch in or out and back lighting you would wire it as follows:
Spade #7 connect to ground wire. (There is no #8 position spade)
Spade #2 & Spade #5
are for power source in - either from PDM or key on power source (Honda Black wire with white stripe) These can be jumped together, one wire in then jump to the other makes no different which one both have to have power in.
Spade #1 & Spade #4 are to Relay or accessory powered on when rocker is pressed UP (typically only need one of these, unless you are rocking double winches on same bumper)
Spade #3 & Spade #6 are to Relay or accessory powered on when rocker is pressed DOWN (typically only need one of these, unless you are rocking double winches on same bumper)
This type of rocker only lights up when you are holding the rocker up or down.
For a 5 Pin Rocker Switch from STV that is a ON / Off and back lighting you would wire it as follows:
Spade #7 & Spade #8 connect to ground wire. These can be jumped together, one wire in then jump to the other makes no different which one both have to go to a ground.
Spade #2 for power source in - either from PDM or key on power source (Honda Black wire with white stripe) These can be jumped together, one wire in then jump to the other makes no different which one both have to have power in.
Spade #6 is for Light source power in (Honda Brown wire) Switch will be backlit when lights are turned on only.
Spade #3 to Relay or accessory powered on when rocker is flipped ON or Up
There is no spade for positions #1, #4, #5 on the 5 terminal rocker switch.
RANGER1
5
0
TN
Where are you located. I am close to royal blue.
273,521
Literally on top of the mountain immediately West of the town Pioneer overlooking Elk Valley. 7 miles to I-75 exit 141 via TN 297 & TN 63
273,521
Questions?
1. Did you drill into the roll cage and hood to mount your 4 cube lights?
2. Can you explain what the bellows are for on the differentials and transmission?
No I didn't drill any holes to run wiring ran heavy insulation trailer wiring 14ga x 4 wires along ROPS to power rear light bars and pods.
Bellows were to eliminate possibility of contamination (water) entering via open vent tubes.
273,521
Haven't posted any updates in a while currently addressing in cab heat. Insulation installed the right way under the plastic and double layer between seat belts next to head and header pipes along with 4" bilge fan. Removal of seat back and plastic cover between seat bottom and back. Insulation BEFORE it heats up the plastic next to the occupants.
20160729 110216
20160729 110211
Will post as insulation is installed. Why is it so hot normally because only 2" gap and 1/8" of plastic separate engine from occupants. 20160729 104702
Reactions: CumminsPusher
322,675
The town of Pioneer! You hold back no punches:) I love it!
Sent from iPhone
Reactions: joeymt33 and JACKAL
273,521
Tired of tiny GPS screens, me too. How about a 10" GPS using an Android based tablet, ORUXMAPS app, and trail files. It is sweet!
20160729 110038
20160729 110035
Reactions: BIGRACK
BIGRACK
BIGRACK
202
376
Dayton Tenn
Will post as insulation is installed. Why is it so hot normally because only 2" gap and 1/8" of plastic separate engine from occupants. View attachment 19185
Jackal on the bulge fan placement Joey and myself angled fan to blow toward header /passenger side it seem to work better . You can feel air moving at rear tire area try engine off and running when it get warm great idea here.
Reactions: joeymt33
solrus
solrus
1,629
2,511
Montana
Montana climate solves my heat problem .
Jackal, is it way more heat on p1000 vs p500?
273,521
Mine does the same you can feel it easily just inside the right rear shock blowing back even when cold.
Reactions: BIGRACK
273,521
With the glass windshield and hard rear panel yes P1K is considerably warmer. My P500 has the Honda tilt windshield crack it open at bottom P500 has no heat at all comparable to P1K.
273,521
Ok so for the heatshield install I removed the seat bottom, seat back, and the plastic that spans the gap between the two.
All stripped down looks like this.
20160729 104650
Fitted front and side edges leaving 2" material tucked down front and sides held by OEM push rivets. Trimmed back and passenger sides, left center full length to fold down in back to double thickness between engine and center seat.
20160729 124512
All tucked in place.
20160729 124657
Center plastic piece back in place.
20160729 130652
Seat back in place.
20160729 133334
Bottom back in all done.
20160729 133519
To check sub transmission I cut out a 8"x8" flap then took a scrap piece 3" longer and wider glued to top of flap. Simply lift up to check oil level then let it rest on top seat holds firmly in place.
Material used was this:
ESP Low-E® EZ-Cool Car Insulation Kit(Includes 40 Sq. Ft Insulation, 10' Foil Tape): Heat and Sound Automotive Insulation For Your Car Restoration Projects - - Amazon.com
Enough for two machines for $33.
Crow_Hunter
Crow_Hunter
750
836
Riding a Canned Ham.
Are you planning anything similar for the floorboard of the back passengers?
I have had the biggest complaints about that heat more than the front seat heat from riders. The seat heat doesn't bother me so far.
My complaint is the hot air in my face from the shifter (like someone breathing in my face, which I hate) and my back seat right hand passengers complain about the heat on their feet.
I am planning on doing the bilge blower but I wonder if some heat tape would help the back seat passengers. It doesn't look like there is a lot of room under there for much insulation.
273,521
To do it right from me looking it over is to insulate the front wall where thier knees are, the panels under thier feet then remove the bed and do it between the plastic and metal frame that supports it. I may do that as I too have gotten complaints from rear passengers.
Crow_Hunter
Crow_Hunter
750
836
I am going to add the bilge fan and put some tape under the "Not A Step" riser first and see how that goes. My wife is really cold natured so I think if I can knock just a little of the heat back right at her feet, she would be fine and actually like it in the winter. Which is another reason why I am hesitant to go too far on the insulation, she might start complaining that she is cold. :)
273,521
I installed the ThrottleMaxx for the P500 / P700 on my P1K. Turns out I didn't have to modify it at all just enough room to bolt right on.
20160729 203943
Took it out for a 30 minute ride wished I had it on from day one. You can literally rest you heel against the back plastic wall and run it up to full throttle with ease. Need more control just slide your foot up 2 inches and you can finesse the throttle through the roughest sections by keeping your heel firmly planted.
Definitely recommend this product.
273,521
Seat back in place.
Took this out for a test ride this evening ran about 30 minutes very satisfied with the results. The in cab noise was noticeably quieter and the heat in the seating area seems completely eliminated. In fact the only heat I did notice was coming from the drive select lever which I had never even noticed before. Will put it to the true test on a 6hr mountain trail ride Monday but I am very happy thus far.
