P1000 Jackal's P1000-5
283,012
Haven't posted any updates in a while currently addressing in cab heat. Insulation installed the right way under the plastic and double layer between seat belts next to head and header pipes along with 4" bilge fan. Removal of seat back and plastic cover between seat bottom and back. Insulation BEFORE it heats up the plastic next to the occupants.
20160729 110216
20160729 110211
Will post as insulation is installed. Why is it so hot normally because only 2" gap and 1/8" of plastic separate engine from occupants. 20160729 104702
Reactions: CumminsPusher
Literally on top of the mountain immediately West of the town Pioneer overlooking Elk Valley. 7 miles to I-75 exit 141 via TN 297 & TN 63
The town of Pioneer! You hold back no punches:) I love it!
Sent from iPhone
Reactions: joeymt33 and JACKAL
283,012
Tired of tiny GPS screens, me too. How about a 10" GPS using an Android based tablet, ORUXMAPS app, and trail files. It is sweet!
20160729 110038
20160729 110035
Reactions: BIGRACK
BIGRACK
BIGRACK
202
376
Dayton Tenn
Will post as insulation is installed. Why is it so hot normally because only 2" gap and 1/8" of plastic separate engine from occupants. View attachment 19185
Jackal on the bulge fan placement Joey and myself angled fan to blow toward header /passenger side it seem to work better . You can feel air moving at rear tire area try engine off and running when it get warm great idea here.
Reactions: joeymt33
solrus
solrus
1,629
2,511
Montana
Montana climate solves my heat problem .
Jackal, is it way more heat on p1000 vs p500?
283,012
Mine does the same you can feel it easily just inside the right rear shock blowing back even when cold.
Reactions: BIGRACK
283,012
With the glass windshield and hard rear panel yes P1K is considerably warmer. My P500 has the Honda tilt windshield crack it open at bottom P500 has no heat at all comparable to P1K.
283,012
Ok so for the heatshield install I removed the seat bottom, seat back, and the plastic that spans the gap between the two.
All stripped down looks like this.
20160729 104650
Fitted front and side edges leaving 2" material tucked down front and sides held by OEM push rivets. Trimmed back and passenger sides, left center full length to fold down in back to double thickness between engine and center seat.
20160729 124512
All tucked in place.
20160729 124657
Center plastic piece back in place.
20160729 130652
Seat back in place.
20160729 133334
Bottom back in all done.
20160729 133519
To check sub transmission I cut out a 8"x8" flap then took a scrap piece 3" longer and wider glued to top of flap. Simply lift up to check oil level then let it rest on top seat holds firmly in place.
Material used was this:
ESP Low-E® EZ-Cool Car Insulation Kit(Includes 40 Sq. Ft Insulation, 10' Foil Tape): Heat and Sound Automotive Insulation For Your Car Restoration Projects - - Amazon.com
Enough for two machines for $33.
Crow_Hunter
Crow_Hunter
750
836
Riding a Canned Ham.
Are you planning anything similar for the floorboard of the back passengers?
I have had the biggest complaints about that heat more than the front seat heat from riders. The seat heat doesn't bother me so far.
My complaint is the hot air in my face from the shifter (like someone breathing in my face, which I hate) and my back seat right hand passengers complain about the heat on their feet.
I am planning on doing the bilge blower but I wonder if some heat tape would help the back seat passengers. It doesn't look like there is a lot of room under there for much insulation.
283,012
To do it right from me looking it over is to insulate the front wall where thier knees are, the panels under thier feet then remove the bed and do it between the plastic and metal frame that supports it. I may do that as I too have gotten complaints from rear passengers.
Crow_Hunter
Crow_Hunter
750
836
I am going to add the bilge fan and put some tape under the "Not A Step" riser first and see how that goes. My wife is really cold natured so I think if I can knock just a little of the heat back right at her feet, she would be fine and actually like it in the winter. Which is another reason why I am hesitant to go too far on the insulation, she might start complaining that she is cold. :)
283,012
I installed the ThrottleMaxx for the P500 / P700 on my P1K. Turns out I didn't have to modify it at all just enough room to bolt right on.
20160729 203943
Took it out for a 30 minute ride wished I had it on from day one. You can literally rest you heel against the back plastic wall and run it up to full throttle with ease. Need more control just slide your foot up 2 inches and you can finesse the throttle through the roughest sections by keeping your heel firmly planted.
Definitely recommend this product.
283,012
Seat back in place.
Took this out for a test ride this evening ran about 30 minutes very satisfied with the results. The in cab noise was noticeably quieter and the heat in the seating area seems completely eliminated. In fact the only heat I did notice was coming from the drive select lever which I had never even noticed before. Will put it to the true test on a 6hr mountain trail ride Monday but I am very happy thus far.
Samiam1286
Samiam1286
29
Where did you get the bilge blower? Make and model number?
Reactions: Hallboy88
V
vitulla
11
Montreal, Quebec, Canada
Wow, what an informative build thread, well done and very well explained. Thanks I will be coming back and doing a few things you have done. Would you happen to have any new pics of the gear rail with rotopax and spare tire?
Thanks again
Danny
Reactions: pct and JACKAL
283,012
I haven't finished that yet been too busy moving and building new house.
Reactions: vitulla
BlueCollarGuy7007
BlueCollarGuy7007
65
69
DFW Texas
Would this help eliminate or ease how touchy the throttle can be @ times? Did not take long & I can drive it smoothly even on rough but I do notice the 1st time any one else drives the machine they end up just short of a case of whip lash. Especially if short & can not rest their heel on the floor. If this will help would be interested in where to get one.
Thanks.
BlueCollarGuy7007
BlueCollarGuy7007
65
69
DFW Texas
Like all on this thread have described the heat can be too much & if driven through deep water will almost have you bailing out to not be scolded - but in the winter months, yeah like that heat coming up behind the seat. Jackal has come up w/ what I see as the best full-time fix but want to ask those who like my self like having heat when they want it is the bilge fan a fix to allow the best of both worlds? Thanks.
