P1000 To Winch or not to Winch..
Would you recommend from experience, installing a front-mounted winch on your Honda pioneer?
  • Yes for sure, and I'll tell you why.
    Votes: 24 82.8%
  • Heck no, and I'll tell you why.
    Votes: 0 0.0%
  • It depends, and..I'll tell you why.
    Votes: 5 17.2%
  • Removed per user request
    Votes: 6 20.7%
  • Total voters
    29
Whiskey1
Whiskey1
131
Arizona
Pondering the install of a front-mounted winch, and being on the fence about it, I want to know what the great folks of SXS are thinking here. I could use the input and insight you have based on past experience, your opinion, or any comments, moans, and/or groans, etc. Much appreciated!
I put 700 miles on my P700 and never once used it to extract my own vehicle. Now, I hve been extracted several times by someone else's winch because I only attempt the harder lines while riding with someone else.
With that said, I have use the winch many times for other uses around my property. This vehicle can weigh 2000 pounds when loaded with accessories and occupants in the vehicle. In my opinion, a winch is a must because it would be very difficult for a Nother side-by-side or ATV to pull you out.
Jack39
64
31
Wareham, MA (near cape cod)
It all depends on your preference where you place it, just be sure to have one! I had mine set up to drop over my trailer ball on my Teryx. I put a front receiver on it and ran power cables to both ends with quick connects on either end. I carried the winch in the storage area. I am going the same route with my new P1K/3 which came in this morning. Thanks to all the great info on this forum, I will install a second battery and switches when I get it home. I am also considering setting up a spot on the ROPS as someone mentioned on this forum, so I can pull heavy objects into the bed. Good luck with your new machine.
Reactions: Whiskey1
TOOLOUD
TOOLOUD
261
155
Benton,La
I've only needed to winch myself out a few times in my xp800 ranger. Honestly I won't own a SXS without a winch for very long. I use my winch to pick deer up into the bed when I'm hunting alone.
Reactions: Whiskey1
266,921
Yes for sure, I'll tell you why... If you ever get it stuck in mud or a hill in a rut and you are all by yourself you cant push, pull, or wish it out. Only the very cheap insurance of a winch can save your "stuck" from becoming a possible nightmare. That being said if you are never leaving the back 40 on you farm that's an entirely different story. In the age old adage of engineering do I need one? It depends on how and where you will use it, but one error in judgment on the trail may make it the cheapest insurance you ever bought.
Carl427
Carl427
29
9
Fort Lauderdale, FL
It depends on where you plan on driving really... I ride in the everglades alot where there is a lot of water and deep mud holes. A winch is a must. I got antsy the first weekend i had it and ventured into the everglades without one. Lets just say by the time i payed someone who was able to WINCH me out of a mudhole.... I could have bought several winches. So if you are going to be on dry, solid, mudhole-less land, no need. Exploring the outdoors on day trail rides through water, hills, swamps and mudholes, yes you need.
Reactions: Whiskey1
ofrcboy
ofrcboy
501
572
Oregon
Install a winch with Synthetic rope and buy a snatch block and a couple of tree straps and shackles. You will find many uses for it.
Reactions: Whiskey1
Gator
Gator
The Most Unknown Member
2,475
10,396
Louisiana
No brainer for me. If I don't have a winch I ain't taking it out there. I don't like the idea of walking out of the swamp in the dark.
Reactions: Whiskey1
67,318
Like stated before, as soon as you get it stuck you'll wish you spent the $300 for the winch, easy installation too.
Reactions: Whiskey1
wyo700
wyo700
413
210
Without question get one. If you only use it once it's worth it. You are going rock out a SXS like you can an ATV. Even then I put one on my ATV because of one time. They are a life saver in my opinion.
Reactions: Whiskey1
Whiskey1
Whiskey1
131
Arizona
Thank you all, so far. I'm starting to lean toward getting a winch, after reading some of the posts. I've looked at the Superwinch and the Warn version (with synthetic rope as suggested above) online. But there are many others (Viper, etc.), even the Honda version. Does anyone have recommendations on brand, load capacity for a P1000M5? Is 4500 lbs neccessary or will a 3k work?
Perhaps more importantly for a guy like me, does the mounting bracket need to be vehicle specific or will a universal install kit work just fine? Cuz, well I look at the installer in the mirror every day, and he has enough busted knuckles to go around.
Reactions: DTAGG
Whiskey1
Whiskey1
131
Arizona
I like that idea. Was that a custom build or was there an available bolt-on front receiver unit? Congrats on the P1K/3 today. There is nothing like a shiny new Honda..
BigRiver
BigRiver
324
79
In the muddy south, you better have one, or at least friends that can pull out out.
67,318
4500lb at least. Warn or superwinch, both work great. And yes you need the brand specific mount.
CPope
CPope
352
1,151
Pulaski TN
I just installed the KFI 4500 stealth winch with the KFI mount, it mounts perfectly and looks very good. The setup is very nice and very user friendly and easy to install. I would recommend this set up and for the price of 405.00 shipped to the door, it is well worth the money.
Reactions: Whiskey1
F
Fullthrottle
164
84
For sure a winch. Dont mount it on top a bumper either when your stuck with these beasts you need to be winching up high on a tree and from down low on your sxs gets that front end coming up out of the mud.
Reactions: joeymt33
Very true. Thanks for reminding me. I've seen the winch high mount cause problems.
A
Alex
6
building a front receiver for mine BUT the right and left sides of the frame in the front are not square with each other. I made the mount fit the bumper three times, adjusting the width each time and still can't get both sides to bolt up to the frame. May try again today or may take the pioneer to work where my welder is and weld together on the pioneer. i had this front rear mount on my Ranger XP and on my big red. The bigred never ran long enough to use. Only got stuck on it once before it blew up. Sitting in the back yard now with 173 hours on it and no compression. The one on the Ranger got used at least 100 times, some front and some rear. Never had to walk home and get the tractor once i put the winch on.
I have never had an issue with a Super winch! I bought the terra 45 at Cabelas for 211.00 out the door. Amazon has the cables already made up for the rear for I think 31.00ish.
ElmerFudd
ElmerFudd
58
108
I plan on a receiver mount winch, with receptacles front, rear, headache rack. Warn style plug ins at all three places.
Anyone know of any brand other than Warn plug ins??
A
Alex
6
super winch sells them also Granger, Mc Master Carr. Just need to know what size wire you are using.
