Toy Hauler P1K5 w/ half ton
elkaholic
elkaholic
Illegitimi non carborundum
2,097
8,606
Ridgeway, SC
One way big way to help sway if you tow alot is to run D rated tires at max psi.
Or load range G which is what is on my toyhauler.
elkaholic
elkaholic
2,097
8,606
Ridgeway, SC
14 ply!!! Did it come with that??
Yes it did. 110 PSI. But we are talking about a camper that is not 1/2 ton towable!
Be3464adfcc94481297b7dcb21da40c8
Reactions: Farmer
Farmer
Farmer
2,907
16,768
Southern MO
I meant D's for the truck LOL. I've never even heard of G's but hey, I bet they help a ton.
Just an estimate, I would love to have each axle weighed though.
Trailer from the factory 5800#
SxS 1200#
WDH and hitch 100#
Occupants 270#
Gear 130+#
Truck is rated at 7800#
I may be closer to 7700# , without weighing each item in the camper , it's hard to say how much crap I have in there. I do believe I am well within the limit's of the truck though!
Y’all need to eat a f***ing burger!
jwfirebird
jwfirebird
927
1,446
western ny
going to use the same gas with same load with any gas motor. if you have a million hp you are only using whatever to haul x load whatever speed is going to be the same with any of the gas engines 8cyl or turbo 6 still using the same power and there fore same mileage. diesel would be different or something grossly huge but most of the engines today are the same. probably going to be more like 5-7 with 11k no matter who made it
Reactions: Farmer and JTW
Or worse...
F507B4C4 438B 4B22 8072 EF81FC3B53E1
Reactions: Farmer
jwfirebird
jwfirebird
927
1,446
western ny
yes, if you have alot of hills or faster speed hwy
Reactions: CumminsPusher
jwfirebird
jwfirebird
927
1,446
western ny
I like palomino seem pretty well built when I was checking stuff out. my coachman was wood too had that for years with no issues. was 90s and traded it fir the 16 I have now
BeerMonkey
BeerMonkey
455
1,515
Mid TN
2018 Forest River Rv Cherokee Wolf Pack 25PACK12, Fort Pierce FL - - RVtrader.com
Anybody ever pulled one of these with a P1K in it?
I have a 23pack15 that fits my 4door turbo rzr. the first time i pulled it loaded with the rzr pulled in i couldnt go over 63ish mph without the camper swaying so bad it almost changed lanes. it was not an enjoyable trip. this was with a 05 f250 with air bags, wdh, and single sway bar. i havent backed in yet and tried it (obviously it will be much better) because it will be tight with the bed situation over head. Ive since added an additional sway bar and im going to try filling the 100gal water tank full and try backing the rzr in.
Wow! That sucks, never had that with my bumper pull Raptor. But the axles were set much farther back on the trailer than what you see on regular RV’s.
