P1000 Toy Hauler
Vikes79
Vikes79
SKOL!
10,833
105,096
South Dakota
me too
44C9C97B 26CD 429A 854E 95D4458611EF
6AA2FF49 7E11 4388 A358 E93CBD2D5659
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
For the OP. Have you looked into the hybrid trailers? They are lighter than the toyhaulers and your machine isnt out of the weather. But can be towed with half ton no problem.
There are several trailer manufacturers out there that will “make” you a toyhauler to fit your needs or if you just need a place to sleep and shower and don’t need a homestyle interior finish you can make your own.
There isn’t a toyhauler made that will fit 2 full size machines. I am having to make my own, but I don’t want a gooseneck and the diesel ¾-1ton that goes with, yes a half ton will haul it based on trucks ratings, the trailer weight with 2 machines and all the stuff will be less than 60% of the trucks rated bumper pull trailer capacity. So with weight as a consideration and the main use being a warm place to cook, eat, sleep , and shower (I have 2 girls, and there are some messed up folks out there if my wife isn’t with us I can’t protect them in a women’s restroom). I am going to build a very condensed kitchen/bath in the front of a 28’ enclosed with extra height and 2’ v-nose. The beds I can make in multiple configurations in the 20’ “garage” area where the machines would be during transport. My concern with an exposed machine is sticky fingers if I stop at Walmart or if I stay at a hotel overnight on the way to my final destination.
Reactions: Mudwing and JTW
schlepprock250
17
42
Nc
Jk, I have a 99 f250 cc srw 4x4 7.3 also. We towed our last two travel trailers over the last 15 years. The 99 did OK. Of course I did all kinds of mods from power to suspension. I have Firestone Ride Rite airbags and weight distribution hitch. I bought a 2014 f250 Lariat srw and it did better but still had to have airbags due to the rear sag,was still challenging at times. Our current TT is 38' in length and about 11500 lbs heavy. Now, I traded the '14 for this 2018 F350 drw and its truly a night and day difference.
IMHO any toy hauler large enough to hold a P1k should be pulled by at least a 3/4 ton.
Sent from my SM-N960U using Tapatalk
Killer223
Killer223
266
535
ya'll are funny, the one guy posted a triple axle trailer and dually truck, then someone said they beg to differ with a tandem trailer and single rear wheel truck. two totally different situations. maybe i'm reading this all wrong.?
the triple is likely 15-20K empty, and the tandem trailers are maybe 15K loaded.... just saying.
as for having to have a WDH, i don't agree, not at all, i've towed my 34' toy hauler without one and knowing how to load a trailer correctly is the key, knowing how to move the weight to get the correct balance. going to a scale and having it weighed.
just my experience. For the uneducated in towing they are a bandaid and not really a good idea. IMO.
i now tow a 34' 5er with SRW cummins. no issues.
Reactions: Plumber32
Schmeg
Schmeg
187
394
Bangor Maine
Yes, my rig grosses at 19K. It’s 43’ long. The first pic is with my (old) dually. My new one is rated at 29K towing. It all goes down the road nice. There is no hiding the fact that it’s,real long. We have a small garage so a Pioneer will barely fit. I used to have an SRW. Now that I have a dually, I haven’t looked back. The 5’er is so big and heavy, I can’t tell when the back end has any toys in it. I thought I would regret a tri axle. So far it’s worked out fine.
3D128CF6 99BD 4CB8 B096 E71F47C6F403 F2A2977E EB79 43AE B963 5B0C7466A2DE
lee
lee
Village Idiot
2,327
13,032
Springfield Ohio
ATC used to advertise as half ton towable.
Just looked at there site and it's all diffrent now.
But I can still find the picture of the p1k.
Your Website Title
They cost an arm and a leg but after having a regular toy hauler I like the idea of it.
There equivalent sized unit is 2k+ lb lighter than my old hauler, and should out last it by a good bit.
As for all the all the pictures of the monster toy haulers being towed with a 3/4 or 1 ton truck I don't get it.
OP asked about 1/2 ton towable, I think your toy haulers might be a little too heavy for a 1/2 ton truck, you guys seam to be in the wrong thread.
Your Website Title
There are some awesome features on that rig. The guys that started InTech actually came from ATC I believe.
Reactions: Vikes79
Your Website Title
Probably lawyers because ½-Tons can be between 7000-14000lb bumper pull tow rating, some jackwagon would pull a trailered overloaded to the gills with the one rated for 7000lb and kill a school bus full of kids with litigious parents.
Reactions: Remington and JTW
HondaRed16
HondaRed16
254
499
Arizona
So not all things are ever equal eh!
My trailer and as others have said have a separate garage that is only 10' with a wall.
To add insulate to injury at least in my case: the fresh water tank 120 gals, the wast tank 40 gals, and the fuel tank 30 gals plus the Pioneer 1100+ lbs are all at or behind the rear axle...poorly engineered at best but you CAN'T move anything to "properly adjust load". It is static.
But, it doesn't weigh that much
Not to mention I was raised in farming, employed in trucking for many years and was DOT certified LEO (ok I'm old LOL) but I think I know what I'm doing.
If you read my post, sometimes it's about SWAY not balance, my trailer due to design is dangerously all over the road when loaded...the only cure to that,,,is some type of equalizer hitch with sway control. So depending on the trailer model, you absolutely need the correct hitch and they do correct the issue...no band aide.
So since the original poster hasn't responded and we don't know what type of truck he has and what model trailer he might want all of the above could apply :D
104,959
You missed the whole point lol I was answering “messing” with him cuz he posted a Dodge (the right tool for the job) he said .I drive a Ford! Had nothing to do with triple axle and a dully vers a SRW and a tandem. If your pulling one of these you know the difference between the two , load distribution and what truck u need Lol. At least I hope? The Ford, Dodge, Gm thing has Ben an on going Fun Bs thing on here for a while. BTW that’s a 1ton PS 8’ bed not 6-1/2 big difference, and a 38’ TH 14k loaded well under the trucks capacity. Been pulling it since 15’ no issues either;)
Thanks for letting me know tho.
Reactions: Vikes79 and JTW
McAdmiral
St Paul, MN
Does anybody know of or have a toy hauler that will fit P1000-5 deluxe with factory roof and tires. With out having to do any mods (lower tire pressure, remove roof) and that is bumper pulled by a 1/2 ton.
3wtrod
9
You might want to look at Logans or Sundowners. They make aluminum, 5th wheel or bumper pull toy haulers. My Look Element enclosed has a rear door height of 81", and my 1000 5 with factory roof has about 2" to spare. We can tow doubles in our State, but I'm not into doing that. So, I'm just going to put in a van conversion type interior. Fold down beds, Thetford cassette toilet, Campchef oven/stove, Dometic chest style frige/freezer, awning and solar. Simplistic, basic, but functional. The trailer is a 16' V nose. Better than a tent but less luxurious than my 43' RV.
Reactions: JTW and TimG
